    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Subtle clunking noise after suspension install
    Just installed my b8 shock / neuspeed springs, and couldnt be happier. I get no noises going over bumps, but when the vehicle is moving slower (10-20mph) and only a larger turning radius, a subtle noise can be heard like a clunking or popping. At idle it also does the noise but it is very quiet. I move the steering wheel one way then it does it on the way back.
    All the bushings were torqued at ride height, i didnt forget the strut washers, new strut mounts were installed, and all bolts were torqued to spec.
    Any ideas?
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Really crank down on everything even if it feels right.
    I had clunking for months, checked the bolts a few times too. Finally found that bottom bolt on the strut was "loose" took a lot to tighten it but that was it.
    Oct 24 2015
    Perth, WA
    Re-torque after riding around for a bit. THings will settle in. That should fix it. Did you get alignment done?
    My respray thread
    Jan 24 2013
    Chicago
    Planning to re-torque everything after I install new control arms & hardware. For now I think it's fine since it's not a daily. Wondering whether I should get a kit or just replace with poly bushings. Anyway, the car sits about 24.75 FTG right now.
    Mar 08 2011
    union, nj
    If you get a chance post some pics, thanks in advance
