Results 1 to 8 of 8
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    My trunk key hole arms the alarm and the driversdoor key hole doesn't
    Ever since I got my car the 2 fobs buttons didn't work. I wasn't able to program them either I tried I could think of. I may just need a vag com to program the fobs so I posted in my regional forums to find one I could use.
    What happens when I turn my key in my drivers door is that it opens my door no beep but when I use the trunk to lock it it does beep and when I arm it from the trunk and it beeps and the red lights start flashing on the inside locks and I open the drivers door it doesn't disarm the alarm so the alarm goes off when I get inside.
    With all of this going on does anyone have a clue what it could be? I remember I had an a4 before this and I believe it did the same thing but I fixed it without replacing anything.
    What would happen if I unhooked my battery overnight? Anyone know a fix?
    Please don't insult me. I've had enough. Only post here if you'd like to help.
    Sep 09 2014
    Grand Rapids, Michigan
    You can't program a key fob with a vag com. You'll need 2 fobs. One in the ignition and 1 in the drivers door. Seems strange. I wonder if the micro switch in the door is broken or there's a wiring issue. Check the plugs between the doors to see if they are all intact. It might come down to having to pull the door apart and taking a look.
    Feb 27 2011
    Winnipeg
    you can use 1 fob in the trunk instead of drivers door for programming
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Switch in the door latch is bad or unplugged. Blame New Jersey if it is unplugged
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 02 2004
    UT
    Quote Originally Posted by seanf86 View Post
    Working on it. I van get the fob to make the lights flash once even so I know I'm close.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by derek2079 View Post
    Once you get the flash wait 10 seconds and click unlock again, doors should unlock and it's programmed
    Sent from my XT1058 using Tapatalk
    Aug 02 2004
    UT
    No luck.
    Aug 02 2004
    UT
    When I read the codes with vcds lite it said adaption limit surpassed.
