Selling all of my car parts. No more time for projects.
1. AAN block bored .5mm over. Also
has been hot tanked, honed, & decked.
Includes a polished aan crankshaft. Price
is $800 + shipping. Shipping is not bad
through freight companies.
2. Good condition AAN head. No cracks in
the combustion chamber and it has good valve
guides. Valve seats have been reground
as well. The only flaw is a tiny crack on
the passenger front side of head where the
valve cover mates to the head. Not crucial
as no compression is held there. This head
has been pressure tested & verified before
machine work was performed- The head has
also been decked- Price is $500 + shipping.
3. Custom JE pistons. Took 5 weeks to arrive.
Price is $700 shipped. Specs below:
Bore: 81.5mm
Stroke: 86.4mm
Comp: 9.5:1 good for pump, E85, & race gas tunes
Coatings: None
Wrist pins: Base JE's
4. Integrated Engineering 5cyl rods- $462 shipped
Specs:
A: non rifle drilled
B: Forged H-beam
C: ARP 2000 rod bolts
5. Issam/FRP plug & play AAN Fluidampr- $700 shipped
6. 034 tilton twin disc kit- $1500 shipped
Contains the following:
A. 034 5cyl tilton aluminum flywheel- cost $695 before shipping
B. Tilton twin ceramettallic clutch kit- cost $920 before shipping
C. 034 Tilton throwout bearing- cost $175 before shipping
D. 034 tilton pilot bearing
E. 034 hardware
7. Supertech dual valve spring & titanium retainer kit-
$400 shipped
8. New INA stock weight lifters- $110 shipped
9. 034 billet cylinder head freeze plug-
10. New aan check valve- $27 shipped
11. New IROZ 3" AAN downpipe- for aan
cars & turbos with v-band discharge- price
is $350 shipped
12. New from the dealer inner aan timing
belt cover. Price - $150 shipped
13. New turbo return nipple- $27 shipped
14. AAN metal thermostat housing
15. 034 billet coolant flange
16. New upper block coolant nipple
17. ARP headstuds- $125 shipped
18. Victor Reinz top end reseal kit- $150 shipped
19. ACL race rod bearings +0.001" - missing one cylinder
$100 shipped obo
20. 034 coated main bearings- $150 shipped
21. ACL main bearing (non coated, stock size)- $75 shipped
22. Sand blasted mint aan windage tray- $75 shipped
23. Sand blasted aan oil pan- $100 shipped
24. Refrurbished motor mount brackets- $100 shipped obo
25. Refurbished coolant pipes. $100 shipped for all 3
26. Refurbished snub mount bracket- $50 shipped
27. 034 urS snub mount & bracket- $50 shipped
28. TRW urS front control arms with AK motorsports
track poly bushings installed in them- price is $200 shipped
29. Factory serpentine belt for Euro urS
cars with no a/c. Price is $100 shipped
Will include a regular urS gates belt with
1k miles if you want it.
30. Issam INA billet crankcase breather-
$150 shipped. Has -12an fitting.
31. Custom made -6an turbo block
return port- $50 shipped
32. 034 aan stainless valve cover hardware
33. Sand blasted oil filter housing- $50 shipped
34. Factory GKN urS axle core set- $250 + shipping
35. New factory aan main bolts,vwrist pin
clips, and dampener 24mm center bolt-
$40 shipped
36. two aan valve covers- $50 + $19 for shipping
37. urS to ev14 injector adapters- $25 shipped
38. urs6 headlight washer delete trims- $65 shipped
39. custom made air leather urS e-brake handle- $65 shipped
40. urs4 euro headlight glass- $125 shipped FIRM
41. MOMO early audi aftermarket steering wheel hub-
Price is $75 shipped
42. New genuine leather urS e-brake boot- $35 shipped
43. 3 new urs6 front grill badges- $100 shipped a piece.
You will not find these anywhere.
44. 3 new s6 plus steering wheel badges- $50 shipped a piece
45. 1 audi sport steering wheel badge (new)- $100 shipped
Rare find
46. good condition stock AAN damper- $150 shipped
47. Supertech 5cyl valve stem seals- $65 shipped
