Results 1 to 12 of 12
    Aug 06 2014
    California
    ecs carbon fiber mirror help
    anyone I would appreciate the help if you have any experience. im trying to remove the bottom piece of the our mirror before I remove the mirror motor anyone have any tips to remove this black plastic piece on the bottom?? @ecs
    Mar 21 2015
    Quote Originally Posted by Michaelds4 View Post
    Did you read the install instructions
    Aug 06 2014
    California
    I did. they explain how to remove it but its not working for me and I don't want to damage this piece since its reused. was hoping for any tips. have you installed them?
    Mar 21 2015
    No but theres a few guys here that have and complaind about some clips and an extra screw behind the mirror.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Here's that thread with lots of details you'll find helpful.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Apr 05 2016
    Portland, OR
    Remove the motor first.
    Here is a good video: https://youtu.be/AIRHQWYW1WM
    I did mine a few months ago.
    Aug 06 2014
    California
    Quote Originally Posted by whiped View Post
    Seems a little different than the ecs instructions but I'll give it a shot. Thanks for the tip
    Senior Member Two Rings yossefay's Avatar
    Jan 11 2016
    Pittsburgh/Youngstown
    How'd it go? I had a LOT of issues with mine but I got tired off the clips and just pressed on the bottom piece until it popped off.
    2018 B9 RS5 in Nardo Grey | 20' BBS CH-R's | Milltek Non-Resonated Catback | Carbon Imports CF Lip Spoiler | 35% Tint
    | 285's |
    Nardo RS5 IG
    Aug 06 2014
    California
    Quote Originally Posted by yossefay View Post
    haven't even attempted to try it again since im in the process of doing quite a bit of other jobs to the car. did you just push down the bottom piece with some pressure?
    Apr 05 2016
    Portland, OR
    My first one took two hours. Second took 15 minutes.
    One broken clip on the first, none on the second
    Oct 02 2006
    Wadsworth,OH
    Best advice we can give is to take your time. Reading over the install instructions a few times helps as well.
    Jason
    Jan 11 2016
    Yeah. I broke one clip and I did it on both an RS5 and my S4 so I'd say to just go that route if you're tired of trying.
    Sent from my iPad using Audizine mobile app
    | 285's |
    Nardo RS5 IG
