Results 1 to 12 of 12
Thread: Is it Xenon?
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Is it Xenon?
    Do the 2003 A4 convertible's have xenons as standard? How would I be able to tell it where xenon or not?
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    The best way to make sure is to take a look at the sticker on the headlights and check their part number:
    Headlight Assembly (A4/S4 B6 Cabriolet, Xenon, Right) - 8H0941030AJ
    Headlight Assembly (A4 B6 Cabriolet, Halogen, Right) - 8H0941004AG
    Also, an easier way is to look at the back of the bulb cover if yours is still there. Typically, Xenon headlights will have a yellow high voltage sticker warning like this:
    If you look closely at the picture above to the left of the yellow sticker, you will also find an imprint on the housing like this if you have Xenons:
    H7
    D2S
    W2W
    D2S is a Xenon bulb type.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    Quote Originally Posted by eljay View Post
    H7
    D2S
    W2W
    X2
    I don't believe xenon is stock in those A4s. I do know they are more common than not, however.
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Jan 11 2014
    I have the KZ2 sticker, but it says
    1-H9
    1-H7
    1- 2357A
    But both headlights have a blue huge to it, ( The one more blue than the other) and it has headlight washers. I'm so confused
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Get your car facing a wall and turn the headlights off. Give them 5 mins or so to cool off and then turn on again. Xenons usually take a few seconds to come up to full brightness and it's relatively obvious to see when watching the light pattern up against a wall.
    Jan 11 2014
    Still have no clue LMAO
    Aug 26 2005
    No B6 A4s had HID xenon headlights as original equipment. In every case they are an extra cost option. Another way to tell if your A4 has HID headlights, is when they are first turned ON, HID lamps will brightly flash, then continue to get brighter for 10 seconds or so. Standard halogen incandescent lamps, when turned ON are at full brightness immediately and don't get brighter as they first warm up from cold over several seconds. As a practical matter, if you don't know or can't tell that your A4 has HID headlights, it probably doesn't.
    Vorsprung durch Technik
    Jan 11 2014
    It's weird because the light is very similar to the Cayenne Xenon's. But in the Audi they don't self level. So is that mean they are not Xenons? I did your test but I'm still confused. lol
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Quote Originally Posted by AUDIMAN33 View Post
    1-H9
    1-H7
    1- 2357A
    H9 High beam bulb type
    H7 Low beam bulb type
    2357a Turn signal
    If were a factory xenon, low beam would be D2S bulb. Audi never used an H7 xenon bulb. The blue hue you are seeing is likely from the cutoff shield dissecting the light.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by AudiSport12 View Post
    2357a Turn signal
    It could also be a D1S if it were xenon, and most A4's had D1S bulbs. AFAIK, only early 2002 models had D2S. My guess is that if they look the same as HIDs, someone retrofitted an HID kit into the halogen housings.
    Feb 17 2006
    Coastal Georgia
    I gotcha. B5's only hav D2S for OEM xenons but I do know there are no OEM H7 xenons. And good thought on someone maybe using a H7 xenon kit. I didn't think of that earlier.
    OP, best way would be to pull the bulb and post a picture.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2000 C5 4.2Q - Sold
    Jan 11 2014
    I'm 95% sure that theres no HID kit. The car belonged to a Lawyer since new, then she gave it to her husband. Who only used it to drive to the train station.
    - - - Updated - - -
    Lets say it is Halogen, anyone have experience with LED headlights?
