Hi.
Im wondering if anyone has been able to replace the ABS module without having to undo the break lines and remove the pump.
Im looking for some pointers on either unsecuring it or removing completely. I know if i remove the ABS pump and re attach i have to run it with VCDS which i would like to avoid the agro of doing.
It looks like i would have a little play to move it about if i was able to unsecure it. Currently im having issues figuring out how to actualy unsecure the pump from the car. i can see/feal there are rubber grommets on the bottom that look like its holding it in but other than that i havent been able to find any info at all on the googles about replacing the pump to help me un-seucre it.
My main motive for this is because i would like to complete the TMPS and AHHA retrofit and my ABS module does not support this so it needs to be swapped with one that does. There are 4 hex screws holding the module to the pump that i need to get to.
As you can see from my picture i need to replace the black module thats butted up against the car.
so i need to get to these 4 hex screws and have enogh room to pull it off
when i complete this (even if i have to remove the whole pump which i would like to avoid) i will post my steps to this.
Thanks
