Results 1 to 4 of 4
Thread: E85?
    Aug 31 2016
    Sellersburg, IN
    E85?
    What all do i need to do to my car in order to run E85 in 1.8t mk1 quattro
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Typically injectors, fuel pump, and a reprogrammed ECU. E85 has less energy per gallon that gasoline so the engine needs to pump more. Your fuel economy will also go down.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Aug 31 2016
    Sellersburg, IN
    I get that. But will factory fuel lines be sufficient?
    Apr 20 2015
    2008 Audi A4Q (B7), 2001 Audi TTQ (225), 2011 VW Tiguan S
    Huntsville, AL
    Quote Originally Posted by tyler.bary View Post
    Factory fuel lines will be sufficient. It's also nice to know whether the car is Narrowband or Wideband. If narrowband, you'll need to convert to wideband (harness, wideband O2 and wideband ECU with Immo Defeat) to maximize an e85 tune.
