Originally Posted by
jonan
i keep reading about plastigages, micrometers and clearances...is there a particular site or thread that i can read to really learn about measuring clearances?
You need a basic performance engine building book written for non experts that describes all the fundamentals for assembling engines. One title is "Engine Blue Printing" or similar usually available at Barns and Noble. This book details all aspects of building a performance engine from the viewpoint of insuring all the parts are actually as designed by the factory, and how to measure everything in order to be sure the engine is actually assembled to the design specifications. The text will cover everything starting with the block and cylinder head preparation, including cleaning and machine work usually done. Then details prep of all the parts like rod and main bearings and crankshaft and cam shaft installation, piston/conrod assembly and piston ring fitting details. Engine blue printing means making sure the engine actually conforms to "the blue prints", as designed by the OEM factory. This is the engine condition that is baseline for any performance modifications. The book describes everything including measuring all the parts, how to assemble the short block and head with the specified clearances, and details for balancing the engine for smoothest operation etc. This book covers all engines discussing all the general principles involved for all types and designs.
