Results 1 to 4 of 4
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Bump Stops needed for Bilstein B8's?
    Im wondering whether others have used the oem non-sport bump stops and dust covers with a b8 suspension strut from bilstein. Was any trimming required, and if so, how much?
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jan 24 2013
    Chicago
    I just ended up cutting two inches from a stock suspension setup.
    Oct 24 2015
    Perth, WA
    Yes yes you do need them, it says so on the product literature. I have sports suspension so I didn't cut anything off. Coincidentally, I am installing them right now :)
    My respray thread
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by Okedokey View Post
    I have the solo-werks coilovers and for the rears it says to use the OEM and the front use what they provide for bumpstops. Confused to as why they used 2 different ones but eh.
    Anyway I would recommend it if possible, may as well keep them as clean as possible and you don't want to kill your brand new strut :D
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
