Results 1 to 8 of 8
    Junior Member Two Rings
    Nov 22 2014
    Cheshire, CT
    spacers require hub centric rings?
    I measured my hub lip and it's less than a cm, so if I use 12 mm spacers I will need some sort of hub centric ring, right? I'm just not clear how it will help cause it won't reach the original hub lip.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    The spacers should be the hub-centric type. That's the best way to go.
    Jul 10 2014
    12mm spacers should have a hub built into them, and slide right on... At least ECS' do...
    Nov 22 2014
    Cheshire, CT
    Perfect that's who I was going order from. Thanks
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    What you want is a hubcentric spacer like H&R makes:
    You'll also need longer lugbolts as well which would ideally be a 14x1.5x42mm R14 ball seat with 17mm head
    Nov 22 2014
    Cheshire, CT
    ECS puts the hub centric lip n their 12.5 mm spacers but not the 8 mm - so let me look at H&R - thanks.
    Established Member Two Rings Hrp783's Avatar
    May 07 2014
    F-150 Larriett, Infiniti G35 sport
    Austin Texas
    I got 12.5mm fronts and 20mm rears
    ECS awesome!
    Sep 28 2010
    NW NC / DE
    We've got some really nice SP branded spacers. They're even notched for removal. We have 3/5/8/10/12/15 and 20mm ones.
    And yes, even 8/10mm spacers have the HC ring integrated.
