Results 1 to 17 of 17
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    CTS or APR Intake
    I recently switched from Stage 1 & 2 APR Carbonio intake to the CTS Turbo intake. Feel no difference, however the sound difference is very noticeable. CTS is MUCH louder.
    With this being said... I'd like to hang on to the intake that yields the most HP/TQ gain on my SQ5. Experience or opinion, which one would you all say is the better option?
    I live in South Texas where it's HOT and very humid almost all year.
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Jun 12 2015
    CA
    Do you have a vagcom? If so, log the air mass with both. You'll probably find the differences to be negligible. When I switched from a modified airbox to a cts turbo intake, my peak air mass went up, but so did my iats (here in the summer). So it was a bit of a trade off.
    Veteran Member Three Rings rusq5's Avatar
    Mar 27 2015
    SF Bay Area
    From what I've heard, the stock airbox performs better than the CTS. The CTS design seems like it would give warmer air temps.
    I know 034 has been working on a new box, but admit the stock one works very well. I'd lean more towards the APR, but I've got no data to back that up. I think finding a real world measurement will be hard, on a dyno an open hood and fans will skew the results.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Jul 10 2014
    Quote Originally Posted by rusq5 View Post
    But that whine tho!!!
    Feb 03 2015
    Texas
    I can watch the IAT using my P3 gauge and the temp stays right at the outside air temp or a degree under... Which seems normal because how could it be any cooler? (I currently have the CTS installed with the APR sitting in garage.)
    Hmmm... What a dilemma. :P
    - - - Updated - - -
    Quote Originally Posted by Silverarrow240 View Post
    Yes, the SC whine with the CTS is insane.
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Pretty sure we've had this discussion before. The APR isn't an exact fit to the Q5/SQ5. So that may be your answer.
    If you like open design stay with what you've got.
    I personally chose the AWE S-Flo box with 034 Hose.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    Quote Originally Posted by ThunderDent View Post
    did you freaking install it yet lol, im waiting <3
    Veteran Member Three Rings turbojayc's Avatar
    Sep 11 2015
    An ignorant reply perhaps, but here goes.
    Just do what you like. I think the losses/gains with a CAI are so minimal. I currently run the CTS. Love the sound, car is Stage 2+Pulley tuned so it's fast and thats the way I like it.
    2023 S3 - Daytona Grey Pearl | H&R Sport Spring | 19" Rotiform OZR | Unitronic Stage 1+
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 14 2012
    Ona, WV
    Not yet. I'm a slacker.
    Still waiting on my last carbon bits from Berlin.
    Everything else is done
    Current Stable:
    Past Whips:
    Feb 03 2015
    Texas
    That's strange. I had the carbonio on my SQ5.. Fitment was spot on.
    May 27 2016
    Atlanta
    Quote Originally Posted by turbojayc View Post
    Same here. I like the CTS I have installed with my stage 2 and 034 intake. Looking into AWE cooling reservoir now to help with heat soak.
    Sent from my SM-T813 using Tapatalk
    Established Member Two Rings Hrp783's Avatar
    May 07 2014
    F-150 Larriett, Infiniti G35 sport
    Austin Texas
    Bump
    Oct 26 2015
    Norman/OK
    I went back and forth with this, CAI for an Audi are expensive, I guess it is the German tax. I ended up reading on the modified stock airbox thread and that the OP ran several test which showed a 1psi increase on the stock airbox. So I went the 034 intake tube hose, AWE S-Flo drop in filter, removed the snow guard and modified the entrance into the airbox and cut open the circular opening. The SQ5 responded very well to those mods, very well. That is the route I went and will stay with. next up is the EPL Stage I and II pulley and tune maybe next year.
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by rgvsq5 View Post
    - - - Updated - - -
    I've got the P3 and was disappointed to learn that the air temperature it shows is at the air intake not IAT after the intercooler. I contacted P3 last spring and they stated they were working on a product that would let users select different data values to display and other features. A couple of weeks ago emailed for an update, they still don't have a release date but it is a product they stated their still working on.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    I like UPS intake design, it has recorded some good dyno #'s
    I dont think they are manufacturing it anymore though?
    If I have time, HA, im going to manufacture my own.
    2013 Q5 3.0T | 57mm | 194mm | EPL DP Tune | Injen Intake
    2009 Aprilia Dorsoduro | TI Fuel Exhaust
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by TJay74 View Post
    I've done the same thing. I do know I could get more with a proper airbox. The tune had to be dialed back a bit for the stock airbox.
    -Rusty
    IG: @grn_rs6
    May 21 2010
    I have read that there is virtually zero HP/TQ gain from these things.
