Results 1 to 6 of 6
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Anyone have experience with CTS turbo's silicone MAF hose?
    Hey guys,
    Since I'm ditching my intake setup and going back to an OEM airbox / RS4,
    I've been considering either running an OEM RS4 accordion or 034's silicone RS4 MAF hose. Both around $75. The MAF housing I picked up does not allow the use of a stock accordion due to diameter differences.
    Just came across a CTS-turbo version...
    http://www.emmanueledesign.com/produ...icone-maf-hose
    Since I believe flow performance was negligible between the hoses (according to flyboyS4's testing), I'm looking to buy whats cheaper assuming the CTS one isn't crap.
    Any of you guys run the CTS turbo version or have any better suggestions?
    Thanks
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I have the CTS part on hand, looks about the same as the 034 part did. I don't plan to use it if you're interested in buying a used part.
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by rguil View Post
    How's the fit of that one?
    Jul 01 2014
    'murca
    Does that position the intake tract in the correct place to fit into an rs4 airbox?
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by erykv1 View Post
    depends on your maf
