Results 1 to 4 of 4
    Established Member Two Rings someguy1.8t's Avatar
    Nov 11 2009
    Woodland Hills, CA,
    Please help with part identification!
    Was taking a look around the engine bay and noticed that this part was loose
    I'm assuming this isn't normal. Correct?
    When the cars turned off you can pull it apart. When it's turned on, you can't. The suction is holding it in place, so I'm assuming it's some kind of suction pump/ vacuum check valve. Any of you guys got an idea of what it is and what it does? I've had a P0299 code( turbocharger underboost) and am wondering if this is why.
    I'd appreciate any help and advice.
    Thanks
    Jan 24 2010
    Paramus,NJ USA
    its called a Suction jet pump .
    Ziddy Autowerks
    Nov 09 2016
    Auckland NZ
    It's not loose it's broken. Happened to me a couple months ago. It shouldn't pull apart
    Dec 05 2007
    Ghetto bandaid, but use electrical tape to create a seal if you need to still ride your car till replacement comes in. Any of that stock rubber crap that catches a leak, for that matter. Of course don't treat that as the fix...but it def will work till replacement part arrives.
