Results 1 to 40 of 40
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    First CEL at 53k miles
    Can anyone help me out to what these codes mean?
    I started up my car after some typical around town driving, and these popes up:
    ddress 01: Engine (J623-CGXC) Labels: 06E-907-551-CGW.clb
    Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
    Component: 3.0l V6 TFSIH07 0002
    Revision: --H07---
    Coding: 0A250034052600060000
    Shop #: WSC 06208 000 00000
    ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
    ROD: EV_ECM30TFS0218K5907551E.rod
    VCID: 387F9E58838E92FE86-806C
    2 Faults Found:
    6425 - Intake Manifold Flap; Bank 1
    P2004 00 [175] - Stuck Open
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 85048 km
    Date: 2016.09.01
    Time: 10:45:13
    6426 - Intake Manifold Flap; Bank 2
    P2005 00 [175] - Stuck Open
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 85048 km
    Date: 2016.09.01
    Time: 10:45:13
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
    Component: ESP8 quattro H09 0100
    Revision: -------- Serial number: --------------
    Coding: 291D1A
    Shop #: WSC 06325 000 00000
    VCID: 04073AA887C6061E5A-8050
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 48
    Reset counter: 235
    Mileage: 83774 km
    Time Indication: 0
    Date: 2016.08.17
    Time: 09:29:35
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x07A2
    Hex Value: 0x0015
    Hex Value: 0x1095
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
    Component: BCM2 2.0 H12 0633
    Revision: 00002001
    Coding: 0D814000000000000000
    VCID: 010933BC98D4133671-8054
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    2 Faults Found:
    00955 - Key 1
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 106
    Mileage: 79960 km
    Time Indication: 0
    Date: 2016.04.19
    Time: 09:19:49
    02823 - Requirements for Locking the Steering Column Lock not met
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 246
    Mileage: 82834 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:07:48
    Let me know your thoughts! Thanks in advance!
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    What the deuce? Intake manifold flaps on both sides, ABS, steering lock, starter?
    Been in any rain or other adverse weather conditions? Seems electrical. I'd say fluke, but none appeared to pop at the same time... Interesting.
    2021 Audi S4, P34 Intake
    Aug 27 2012
    Earth
    Maybe the intake manifold flappers made the CEL come on? The others might have been soft codes. I'm pretty sure that ABS code was something I did with the VAGCOM after I got the car, trying to program something. Weather has been good. I cleared the codes, so we will see if they come back.
    Aug 27 2012
    Earth
    What I found on Ross Tech:
    18436/P2004/008196 - Intake Manifold Flap; Bank 1: Stuck Open
    Possible Causes
    Vacuum leak
    Faulty Intake Manifold Runner Position Sensor1 (G336)
    Intake Manifold Runner binding or sticking
    Possible Solutions
    Replaced failed vacuum line
    Check Intake Manifold Runner Position Sensor 1 (G336) and wiring, see repair manual
    Check Intake Manifold Flap
    Use Output Test
    Perform Basic Setting (Switch Ignition OFF between Output Test and Basic Setting)
    Aug 27 2012
    Earth
    Found this:
    Dec 03 2008
    2018 SQ5
    Are the flap motors prone to issues on this car like they were on b7? With the flap stuck open, you might notice a slightly rougher cold start I think, and maybe lower mpg. It could also be carbon deposits that are restricting the movement of the flaps from inside in my experience with the 2.0t.
    Aug 27 2012
    Earth
    Called the local dealership, both g336 sensors are the same part number: 06E907396G and are $135 each to replace. I guess I will find out if it's just a fluke, or if the sensors will need to be replaced.
    I checked for a vacuum leak, I didn't see any loose lines.
    If the manifold flappers are getting stuck, well I will have no idea what to do about that.
    Aug 27 2012
    Earth
    Not sure - I haven't noticed either loss of power or MPG...
    Aug 27 2012
    Earth
    I'm pretty sure the lock steering column error was during an alignment at the Audi dealership. I took it there on 08/09/2016.
    Dec 03 2008
    2018 SQ5
    If the flaps are stuck open, it shouldn't affect performance. They pretty much only close under very light throttle and during cold starts for emissions purposes.
    Dec 03 2008
    2018 SQ5
    On the b7 there was a way with vagcom to run an adaptation process on the flaps that could sometimes correct the issue if something random was out of whack. Might want to look into that as well
    Dec 03 2008
    2018 SQ5
    Are both banks run by the same flap motor?
    Aug 27 2012
    Earth
    Nope, two separate sensors.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by Frinkferta View Post
    I highly doubt both sides failed at the same time then.
    Aug 27 2012
    Earth
    Saw you said motor, not sure.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    The ABS code is a result of you turning off driver steering recommendation. If you turn DSR back on, you can clear that code.
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    I'd reset and see if it pops again, pretty crazy to think both sides (2 different motors) would trip codes at the same time???
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Aug 27 2012
    Earth
    Quote Originally Posted by MVR 155 View Post
    My same thoughts. I cleared them, so I will report back after a 100 miles or so.
    Aug 27 2012
    Earth
    Quote Originally Posted by Jflow23 View Post
    What does the DSR do? I'll have to look that one up haha!
    Apr 10 2007
    Beaverton OR
    DSR is driver steering recommendation. People recommend turning it off to reduce steering wander and increase steering feedback. I've tried it, did not receive any of the benefits and got that ABS code.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Probably a fluke but could be carbon build up.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 27 2012
    Earth
    I did notice a loss of power in a second gear pull today. Looks like they might actually be stuck open.
    - - - Updated - - -
    Okay, I do remember changing that.
    Aug 27 2012
    Earth
    Aug 27 2012
    Earth
    Ive found these TSBs
    Component Description ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
    Replacement Bulletin Number: 1307
    NHTSA Item Number 10053884
    Date 2013-07-01
    Summary AUDI: DUE TO DEFECTIVE VACUUM ACTUATORS, SOME VEHICLES EXPERIENCE HIGH RPMS WITH A POWER REDUCTION, INTAKE MANIFOLD RUNNER CONTROL STUCK CLOSED (BANK 1 AND BANK 2) POWER AND VACUUM ACTUATOR NEEDS TO BE UPDATED. MODEL 2013 A6, A7, S4, S5 ( ( NHTSA ITEM NUMBER - 10053884 )
    Component Description ENGINE (PWS)
    NHTSA Item Number 10052669
    Date 2013-07-01
    Summary AUDI: ON SOME VEHICLES, A DEFECT HAS OCCURRED ON ONE OF THE VACUUM ACTUATORS ON THE INTAKE RUNNER BANK 1 OR BANK 2 AND NEEDS TO BE UPDATED. MODELS 2013 A6/ A7, S4, S5, S5 CABRIO, AUDI Q7, AUDI A5. ( NHTSA ITEM NUMBER - 10052669 )
    Replacement Bulletin Number: 1306
    NHTSA Item Number 10052646
    Date 2013-06-01
    Summary AUDI: ON SOME VEHICLES, THE INTAKE RUNNER BANK 1 OR BANK 2 IS DEFECTIVE, DUE TO ONE OF THE VACUUM ACTUATORS, CAUSING A SLIGHT POWER REDUCTION AT HIGH RPMS. MODELS 2013 A6/ A7, S4, S5, S5 CAB, AUDI Q7, AUDI Q5. ( NHTSA ITEM NUMBER - 10052646 )
    NHTSA Item Number 10052668
    Date 2013-06-01
    Summary AUDI: ON SOME VEHICLES, THERE IS A DEFECT PERTAINING TO INTAKE RUNNER BANK 1 OR BANK 2 FROM ONE OF THE VACUUM ACTUATORS. MODELS 2013 A6, A7, S4, S5, S5 CABRIO, AUDI Q7, AUDI Q5. ( NHTSA ITEM NUMBER - 10052668 )
    Replacement Bulletin Number: 1305
    NHTSA Item Number 10052276
    Date 2013-05-01
    Summary AUDI: VEHICLES MAY CONTAIN A DEFECTIVE VACUUM ACTUATOR. ( NHTSA ITEM NUMBER - 10052276 )
    Dec 03 2008
    2018 SQ5
    Sounds about right.
    Aug 27 2012
    Earth
    Found this awesome sound this morning coming from the vacuum motor on the driver side.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Eek
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Aug 27 2012
    Earth
    Quote Originally Posted by infinkc View Post
    Eek
    Seriously! The vacuums aren't easy to get to either!
    Apr 10 2007
    Beaverton OR
    Is the sound persistent or does it go away?
    Aug 27 2012
    Earth
    Persistent. It doesn't go away.
    Aug 27 2012
    Earth
    Brought my car into the dealer to have it repaired. Could have been cheaper to replace the part myself, but honestly I didn't even know where to look in my engine bay. Part was $135, it's a vacuum valve with sensor, the part has a "Y" with vacuum lines that goes to both modules to open and close the manifold runners.
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    what year is your car, and what is the total damage from the dealer?
    Aug 27 2012
    Earth
    Quote Originally Posted by mintytoo View Post
    13 S4, $318 out the door. Main damage came from the $165 diagnostic charge. Ripoff...
    Jan 18 2015
    Diagnostic charge wasn't rolled into credit towards the service? That's the way it was with my subie.
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    That's bullshit,,dealer i go to will waive the diagnostic fee if they do the repair..bad dealer..
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Mar 31 2017
    Yorkshire UK
    Hi guys, I have a similar issue at the moment, fault code for bank 1 intake manifold flap stuck open.
    When i try to actuate the vacuum cell unit i can feel the inside of it like kind of crunching, doesn't feel like the flaps are just the inside of the vacuum unit,
    Just had a thought... I recently had a new super charger pulley fitted and the garage who fitted it removed the charger, I had the CEL light come on that night but the code was stored from the time that they were working on the car, could it be possible that they have moved the flaps and put the charger back on in a position that has caused the flaps to become stuck which has then made the vacuum unit chew itself up?
    MK1 Leon Cupra TDI gone but never forgotten
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    Yes.
    [QUOTE=Ford Prefect;12279866]For future searchers, here are two pics, the first is how it should look and the second is how it shouldn't upon reinstall. I recommend you keep making sure they move as you go through the torque sequence. One on the end popped back over, so I was glad I kept checking.
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by cocadave View Post
    The flaps are integrated into the intake manifolds, so unless they removed those it should not have been an issue. The pics above are from my carbon cleaning. Just removing the SC won't cause this, unless of course they monkeyed with the vacuum hose or disconnected the electrical connectors (but those might be just position sensing).
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by Ford Prefect View Post
    This. They should not have needed to remove the manifolds if only changing the s/c pulley via removal of the charger.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    My car is currently being diagnosed for sticky manifold flaps, started with EPC lights then developed into CEL. Its the 2nd time Ive taken it to an Audi Indy shop to have it looked at, this time they might be replacing Bank 1 manifold if they can confirm thats the issue. Ill post an update this week
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
