Vivid Racing Presents: BSH Speed Shop MK5 Performance Parts
PM, call, or email for FORUM Exclusive Pricing!
[email protected] | +1.480.966.3040 x225 | www.vividracing.com
Whenever we get new products available, we like to inform you guys first. We now have teamed up with BSH Speed Shop and we carry their full line of products available for the 2.0T platform. Any questions or inquiries? Feel Free to call, email, or post any questions you have!
BSH Heatshield
Product Information
Made out of brushed aluminum this simple yet effective heat shield will mount to your vehicle utilizing the rear mounting pegs that the factory engine cover sits on. It's designed to block the heat rising from the exhaust manifold and the turbo resulting in lower intake temperatures and more power.
Features:
brushed aluminum
Easily Installed
blocks the heat
Increases Power
Fitament:
Volkswagen Golf/GTI MK5 05-09
All US Spec Transverse 2.0T FSI Vehicles
Most international 2.0T models
BSH Pendulum Mount MSRP: $149.99
Product Information
BSH brings you the strongest and most feature rich street performance motor mount kits available. Each component has been designed to accomplish rock solid performance while still maintaining the finesse of a daily driven street car. For optimum results this mount should be paired with the BSH Engine Mount.
As we are sure you've noticed the factory motor mounts have a ton of give in them. Our billet mounts reduce the ability of the engine to flex back by replacing the factory fluid fillled mounts wth street performance bushings and the billet bodies to hold them. This bushing set does a great job of limiting movement while still maintaining an acceptable level of comfort needed to be used on a daily driven street car. This both greatly enhances the fun factor and performance of the car and also removes the all too common problem of blowing out the factory mounts on your higher powered setup.
Features:
Significantly reduced engine movement.
More feedback from the engine
Greatly reduced wheel hop
More defined throttle input
Smoother shifts for both DSG and Manual cars
Fitament:
Volkswagen Golf/GTI MK5 2009
Transverse mount engines
TSI 2.0T, 2.5L, 3.2L, and 3.6L applications
BSH PCV Revamp MSRP: 99.99
Product Information
Designed with simplicity of install in mind the BSH PCV Revamp kit takes care of the commonly occurring PCV issues in tuned 2.0T applications. Manufactured here in the USA, the CNC machined BSH PCV Revamp fixes the major problems with the 2.0T PCV system once and for all!
Features:
Billet Valve Cover Plate
Billet PCV Adapter
Billet Manifold Cap
O-Rings
Retaining Hardware
Notes:
Installs in under an hour
Fully Compatible with BSH Boost Tap and factory engine cover
Fitament:
BSH FSI Competition Catch Can MSRP: 309.99
Product Information
Take your PCV fix one step farther with the addition of a high capacity BSH Competition Catch Can. Our program began with the PCV revamp which solved the issue of failing factory check valves and has since evolved into complete PCV management. By adding our catch can system to your 2.0T FSI you are not only implementing a 100% PCV fix, you are also protecting your stock or tuned motor from the drawbacks of allowing blowby gasses to enter your combustion chamber. As the FSI engine is both high compression and turbocharged, allowing volatile oil vapor access will reduce power across the rev range by making the engine substantially more prone to pre-ignition/detonation. Keep your timing up and a smile on your face by getting those gasses out of your engine. The BSH Catch Can is a complete PCV replacement, is easily installed, and fully compatible with the factory engine cover and BSH Boost Tap. If you already have the BSH Engine Mount please select yes so we can ship with the correct bracket spacer.
Features:
BSH High Capacity Catch Can
BSH Billet Valve Cover Plate
BSH Billet PCV Adapter
BSH Billet Manifold Cap
BSH Billet Valve Cover Fittings
BSH Billet Dip Stick
Laser Cut Catch Can Bracket
Integrated O-Ring Sealed Drain
Oil and Heat Resistant O-Rings
Retaining Hardware
Push Lock Hose
Fitament:
BSH True Seal Short Ram Air Intake MSRP 299.99
Product Information
BSH is proud to bring you the most powerful intake system for the 2.0T FSI. Major design features include a proprietary airbox that integrates into the fresh air ducting on the grill of the car. This design ensures that only cool air enters the engine providing you with the most dense oxygen rich air possible. Other considerations include a carefully calibrated MAF sensor flange and an integrated port for the relocation of a diverter valve.
All of these features combine to bring you the most potent air intake on the market.
This part is a direct replacement for the factory intake system and installs without any modifications to the vehicle.
Features:
Intake Tubing with integrated DV relocation bung and CNC machined MAF flange
True Seal Airbox with Rubber Trim Lock
Proprietary BSH Air Filter with Inverted Cone Top
All clamps and hardware needed for installation
10-15 HP 10-15 Torque
Fitament:
All US Spec Transverse 2.0T TSI Vehicles
BSH Integrated Throttle Pipe MSRP: $169.99
Product Information
BSH is proud to offer the only truly integrated charge pipe system. Featuring a reduction in bends and no diameter changes this addition to your intercooler system will prevent added turbulence to incoming air to the engine providing smoother power delivery and greater top end potential. Integrated into our throttle pipe system is a CNC machined *next generation* water methanol injection bung and a CNC machined noise pipe/dv relocation port. These options set you up to seamlessly integrate any and all options (including full noise pipe delete!) without needing to fabricate your own solutions.
Features:
BSH Silicone Hose Kit
Methanol Bung block off plug
O-Ring Sealed DV port block off
Hose Clamps
MAP Sensor Hardware
Fitament:
Volkswagen Golf/GTI MK6 05-09
BSH Engine Mount $179.99
Product Information
BSH brings you the strongest and most feature rich street performance motor mount kits available. Each component has been designed to accomplish rock solid performance while still maintaining the finesse of a daily driven street car. For optimum results this mount should be paired with the BSH Transmission Mount. As we are sure you�ve noticed the factory motor mounts have a ton of give in them. Our billet mounts reduce the ability of the engine to flex back by replacing the factory fluid filled mounts with street performance bushings and the billet bodies to hold them. This bushing set does a great job of limiting movement while still maintaining an acceptable level of comfort needed to be used on a daily driven street car. This both greatly enhances the fun factor and performance of the car and also removes the all too common problem of blowing out the factory mounts on your higher powered setup.
Features:
BSH Torque Mount Insert MSRP $39.99
Product Information
Under hard acceleration, your engine and transmission rotate due to the soft rubber used in the factory bushings. While the soft factory bushings do a good job of dampening engine vibration, they also create a rubbery, vague response from the vehicle.
The BSH torque arm insert works in concert with the OE rubber bushing. With the insert installed, you car's throttle response will feel better and your shifts will feel more crisp and defined as the urethane reinforcement will aid in limiting the amount the engine can rock back under acceleration.
Fitament:
Volkswagen Golf/GTI MK5 06-08
FSI 2.0T, 2.5L, 3.2L, and 3.6L applications
Manual and DSG equipped cars
BSH Boost Tap MSRP: 38.95
Product Information
Nothing says "almost there" like a bunch of t'd off lines cluttering your engine bay. BSH helps you tidy up your lines and provide a proper signal for your components with use of its billet boost tap for your FSI or TSI equipped vehicle. Utilizing CAD drawing and CNC Lathe machining this part is a perfect fit every time. The BSH boost tap comes with two ports so you can run your boost gauge, dv, methanol injection, or any other part you may want that requires a boost or vacuum signal to function.
Features:
Billet Boost Tap
O-Ring kit
Retaining Hardware
Vacuum Nipples
Ordering:
Phone:
You can reach me directly by calling +1.480.966.3040 x225 to place your order over the phone.
Payment Methods:
- Credit/Debit Cards (Visa, MasterCard, Discover, American Express)
- PayPal
- Affirm – Now you can finance your parts!
- Bank Wire
- Bill Me Later
- AZ Orders will incur 7.8% sales tax
- All international orders (outside of US and Canada) require Bank Wire or PayPal
Shipping:
We have very competitive worldwide shipping rates. Most orders leave via FedEx, however we do use UPS, DHL, and various freight companies. The most efficient shipping method takes precedence. Expedited shipping is available by request.
Hours of Operation: We do not observe Daylight Savings Time in Arizona
March-October: M-F 9am-6pm PST
November-February: M-F 8am-5pm PST
We are closed for business Saturday and Sunday
Contact Information:
Phone: 480.966.3040 x225
Email: [email protected]
Website: www.vividracing.com
Please feel free to contact me via PM, Email, or Phone if you have any questions.
