Results 1 to 14 of 14
    Established Member Two Rings AndyB's Avatar
    Sep 03 2014
    Connecticut
    Belly pan/ skid plate - drawing dims?
    Looking to fab a skid plate at my shop to replace my plastic belly pan that was tore off. Does anyone have a drawing with the dimensions of the belly pan? Looking to fab out of aluminum. Any help is appreciated.
    Thanks Andy
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Why not just buy one. Thor Evolution and Dieselgeek Panzer already make them. I have a thor on mine
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    May 18 2012
    2005 S4
    Portland, OR
    Well since he said "fab at my shop," I'm guessing he is going with DIY, which is cheaper, and feels satisfying if you pull it off.
    Aug 09 2012
    Bay Area
    Quote Originally Posted by FastEddie View Post
    Just checked about $250 from diesel. I'd say that's a really good deal considering its almost 100 - 150 for a OEM one.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    hrm, probably the only place to get one would be from someone who's already made a cover. the service manual only has service illustrations, and the parts guide generally illustrates things in perspective without dimensions. i would tape a big piece of butcher paper to the underside to get the rough dimensions, then precisely measure each mounting hole relative to each other and pick one to be your reference.
    hope to see updates if you pull it off!
    - emilio
    May 18 2012
    2005 S4
    Portland, OR
    Well it would be pretty easy to measure the factory belly pan. The only reason OP didn't is because he said it was torn off and is gone. Someone who is changing their oil (Audi should have taken a hint from BMW and put a trap door on that stupid thing) should measure theirs. I'd volunteer, but I try to avoid removing that damn thing unless absolutely necessary.
    Apr 18 2012
    Central Texas
    oh, i know, i meant to use the paper in lieu of the pan. the edges of the pan aren't as important as getting the mounting holes all right; once the mounting holes are spaced correctly the plate can be trimmed and bent to fit.
    - emilio
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    I have the belly pan off on the b7 that I'm parting out... what dimensions are you looking for? bolt locations or overall dimensions?
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    You can get one at eBay for $35. Fits good and seem pretty durable
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I got mine off ebay, pretty durable except the hardware spots, they seem to wear very easy and fall off. need to put washers on mine now to keep them on.
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by Terry.Reese View Post
    thats why i zip tie all the holes lol. easy install and cut off for oil changes
    Apr 01 2012
    Queens
    Quote Originally Posted by Kambesama View Post
    i got mine i believe for just over 200 with free shipping. Plus i have the thor which was bigger than the Deiselgeek.
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    I used the ecs skid plate. Contrary to many, it does fit with the rivnuts and spacers.
    Sent from my SM-N930V using Tapatalk
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Nov 05 2014
    The East Coast, NC
    02' A4 1.8T Quattro
