Results 1 to 8 of 8
    Senior Member Two Rings willroc7's Avatar
    Sep 04 2014
    Allroad Wheels (17x7.5 ET25) on B7 S4?
    There is a cheap set of allroad wheels available local to me and I'm considering running them for a winter setup on my B7. I am moderately lowered on coilovers and would be running 235/35R17 tires. According to willtheyfit.com: "Compared to your existing wheel, this new wheel will have an inner rim which is 26.4mm further away from the suspension strut. The outer rim will poke out 13.7mm more than before."
    Has anyone run something like this? Will I run into any issues with the added poke and almost an inch additional distance from the strut?
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    only thing I can think of is your caliper size, I have an allroad as well and they will not fit on my S4 due to the large caliper.
    Sep 04 2014
    Quote Originally Posted by Terry.Reese View Post
    Thanks for the reply. I'm confused though, I thought the ET25 offset would put the wheel farther away from the caliper than the stock 18x8 ET45 wheel? Or is it the smaller 17" diameter that's causing the contact?
    Oct 05 2015
    Billings, MT
    not sure about the offset, but was told that with the caliper size to not go below 18 inch on rim size without an adapter or spacer.
    http://www.alloywheelsdirect.net/inf...ing_chart/audi here is a list you can compare on though.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    i had 6 spoke 17" wheels on my b6 s4, not sure of the ET or which Audi they came off of
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Oct 05 2015
    Billings, MT
    ?? why the hell did my wheels not fit? I need to investigate this further now.
    Established Member Two Rings B5man17's Avatar
    Jun 24 2013
    MN
    I run a set BBS SR 17" for a winter set with an ET35
    Catless DPs, Magnaflow CB, 034 rear sway and end links, tint 20%, enkei ts9 pss (summer), BBS SR with R2 snows(winter), JHM R1 clutch and flywheel, JHM shot shifter, JHM shift knob, JHM tune, ohlins coilovers, stub trans and rear diff mounts.
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    I once tried fitting my C5 allroad wheels on my b5 (I know, smaller calipers than B6/7 S4), but the rolling diameter was too big due to the larger sidewall of the 225/55/17 allroad tire. The result was that they fit fine on the rears, and the offset was nicely aggressive. However, I couldn't test fit them on the front of the car because the larger tire wouldn't clear the upper control arms (which may have been your issue). My guess is that with the proper tire, they'd fit nicely on a B6/7.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
