Results 1 to 40 of 52
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    wouldn't know 2nd year service Monday, Today Dash warning" replace key battery"
    not a biggy. I bought a ten pack of batteries cr 2032 from merit line about $5 for ten. replaced my self. Sure dealer would do it, but less hassle to do it myself.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Awesome?
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Nice! You should do a DIY write-up for those of us out of warranty.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by fitzydude View Post
    Pull your key out of your pocket
    Look at the key.
    Push the silver button and remove the metal key portion.
    Flip the key over and push the black plastic button.
    Pull the plastic portion out.
    Replace the dead battery.
    Reinstall in the reverse order.
    Congratulate yourself that you were not that dumb to schedule a service appointment for having your key fob battery replaced.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jul 05 2014
    Houston
    Maybe you could record a little video, I'm just still not getting it.
    Aug 22 2014
    bloomfield,ct
    you have to be kidding? Guess not see post #4
    Sep 12 2014
    eGolf
    Pasadena, CA
    Apr 05 2016
    Portland, OR
    With the mechanical key out(The chrome cap) squeeze the little black tab and pull out.
    You have to pull fairly hard as it has an seal to protect from water getting in.
    Geoff
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    WOW! Thanks! I never thought about the battery in the key. Haven't had the warning but since I had a couple CR2032's in the drawer, I just replaced them. Took 5 seconds each.
    Kudo's for the post of the day.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by jygesq View Post
    He's trolling you
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I would probably give this a minus 2 for difficulty on the 1 to 5 wrench scale.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Feb 14 2004
    S Ã C, CÃ*
    My production crew was not available so I had to use my phone. The key is very well made I have to say. I put this diy an 8 out of 10 on the difficulty scale. Opening the car door is slightly less intensive.
    If you still need help you can mail me your key and address and I will come to your place and pick your car up to make sure the new battery works.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Thanks, just pulled mine apart to see. easy fix. That grey gasket sure holds that thing in there tight!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    It's rated as a 3.0volt battery, but new is actually 3.25 volts. Mine was flagged at 3.02 volts, so the system is warning really early.
    Jul 05 2014
    Houston
    Can we make this a sticky!!!
    Jul 14 2013
    British Columbia, Canada
    +1
    I thought removing the supercharger pulley was hard... but this.. wow. thx again for DIY
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Jul 02 2013
    Talked to my SA, he said use of non-Audi batteries in the FOB can void warranty and flag car TD1, highly recommended skilled technician at dealership change them out instead, cost $ 39.75 for battery plus half an hour labor charge.
    Jul 05 2014
    Houston
    Quote Originally Posted by sacandagaD View Post
    Crap, that's a good point.. You should make sure to swap your original Audi battery back in before you take it in for service.
    Jul 02 2013
    Excellent idea, that is the beauty of this forum, take a potential serious problem public, and someone here finds a workable solution to it!
    Mar 21 2015
    I knew this thread was going to be great before the first post was up. I hope this goes 40 pages.
    Jul 05 2014
    Houston
    Exactly, thank goodness for the folks on the front lines fighting the good fight.
    Jul 02 2013
    Wait until someone updates their signature to something like this " Apr Stage 2, Carbonio Intake, Duracell CR 2032......"
    Aug 25 2013
    florida
    bro, please pixlelate my username when quoting about my keyfob issue, i cannot afford a TD1. also please note my SA stated he can replace my batteries for free but my cigarette plugged in dashcam would need to be thrown away or flagged as TD1. please advise
    2014 sfeux p+ 6mt bo nav w/o sd
    Jul 05 2014
    Houston
    That would be ridiculous. You know it's gonna be like 2 weeks before energizer releases that Ultra-Max 2032. And we all know what a flop the Energizer Max 2432 was...
    Jul 02 2013
    That reminds me, SA also said the new battery needs to be coded in order to maximize life. So if anyone wants help, I have a Vag-Com cable and can do locally for beers. Figured I'd just throw that out there to my fellow Audizine peeps!
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Any track slips or dyno graphs for the horsepower gain? Curious to see what everyone is running on fresh 3Vs.
    I heard APR is working on something to really improve performance here as well. I bet we see an APR-2032 in the near future. Pricing is rumored around $50.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Mar 21 2015
    ^ Please don't turn this into another APR thread.
    Jan 21 2016
    But boost season is just around the corner..... #apr-2032
    Mar 21 2015
    Quote Originally Posted by eightamrock View Post
    As soon as I hit the post button I knew I effed up, oh well
    Veteran Member Three Rings emnahum's Avatar
    Jan 10 2014
    After you get the CR-15, you've gotta get the CR 2032...
    2015 S4, P+, 6MT, Mythos/Black Nappa, SD, ADS, B&O, BO, Tech, Opticoat, Xpel Full Hood, 034 Transmission Mount, EC Sways & Links, CR-15
    Previous: 2004 A4 Avant 3.0 V6, 1995 90 Sport Quattro, 1984 4000 CS Sport Quattro, 1981 4000 5+5
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    My air headed, blonde, fake titted sister in law actually went to the dealer and paid something like $50 to get her fob battery replaced. She told me and I laughed in her face like I've never laughed before!!!!! I showed her how simple/stupid it is to replace the battery in the fob and then told her how dumb she was.... It was good entertainment for the day!!!!!!
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Aug 22 2014
    bloomfield,ct
    Sorry my battery is special Camelion brand lithium " changes from boosted version to stock automatically when it senses dealer facility.,
    Really the brand meritline sells is called "Camelion" and no I WILL NOT change my signature
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    This! You are my TD1 saver!
    Mind posting a link to the battery?
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by yjypm View Post
    this! You are my td1 saver!
    www.meritline.com
    Mar 21 2015
    Quote Originally Posted by MVR 155 View Post
    With this comment she deserves to have her pic posted. This made my day when I read it last night.
    Jul 02 2013
    Quote Originally Posted by Oloung1 View Post
    Sorry brother, no can do, you know what they say "pay to play". You knew the possible consequences when you bought the batteries at Walgreens.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    TTIWWOP
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Will this also work on 6mt?
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by infinkc View Post
    lmaoooooo
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Any lightweight batteries for track use?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
