Results 1 to 7 of 7
    Established Member Two Rings AntonioS6's Avatar
    Jun 14 2016
    Connecticut
    S6 C7 4000 RPM Limiter
    I have had this issue 3 times now and the techs cannot figure out what the hell is going on. Anyone else have this issue?
    2018 BMW M5 Black Sapphire Metallic
    GONE - 2013 Audi S6 Phantom Black Pearl
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    I would have him check fuel or oil pressures at the time if he had not yet.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    I would check the cam adjuster
    Sent from my SM-G935U using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Jun 14 2016
    Connecticut
    The last two times it has been the cam actuator or sensor. Hopefully third time is the charm but my patience is running thin after having an oil leak, gas pressure issue, and now this. Seems like every other week I am back at the service department.
    Nov 13 2012
    Chicago
    How many miles are on it ? Was it 2 different actuators replaced or the same one again ? They should be able to see a failing actuator when it want back in last.
    Jun 14 2016
    Connecticut
    Right now it is 43200 miles on it. The first time it happened was July 28th of this year so I would say I probably put anywhere from 1-2k miles on it between then. They supposedly replaced the acuator the in July but I am suspect of that. I'm sitting at the dealer now waiting to see what the next step is, probably a week or two in the shop to replace the cam shaft that is having the issue. Personally I think I have a major electronics fault. I can hear my AWE exhaust from the waiting room up top. I guess that is the only positive I got out of this so far
    Nov 13 2012
    Chicago
    Keep us posted if they find out anything useful today
