Worried about rocks & road debris compromising your fragile oil pan? Then this is MUST HAVE PROTECTION!
Fully constructed from T304 stainless steel & 100% TIG welded, this can handle any abuse thrown at it. Compared to the original fragile plastic oil pan found on the MQB platforms, this is serious stuff.
While achieving protection without the sacrifice of ground clearance, we were able to increase the oil capacity by 1-1.5 Liters. This helps extend oil service intervals & maintains more consistent operating temps.
Features:
  • 11 gauge thick floor section
  • 14 gauge thick wall sections
  • Full construction T304 Stainless Steel and 100% TIG Welded
  • Oil Pan Weight: 8.75 pounds
  • Maximum Height of Oil Pan: 73.0mm
  • Increased Oil Capacity Over OEM: Approximately 1.0 - 1.5 Liters additional
ECS designed & tested, made in the U.S.A.
Be sure to check out our -----> Installation PDF <-----
Fits:
Audi 8V A3 2.0T (2014+)
Audi 8V S3 2.0T (2015+)
Jason
