Results 1 to 3 of 3
    May 03 2015
    United States
    A4 awm 1.8t starting woes
    My 1.8t awm motor has a crank no start issue. If it does start it would happen after I pump the clutch pedal few times and the gas pedal. This problem arises when someone tried install remote start now I drove the car fine but when one day I turned the car off and it had the problem. Now I took out the remote start and wired back everything to normal. Spark plugs were burnt as black and just lost? Now let me mention again if it does start the idle is erratic and eventually dies out.
    Established Member Two Rings mmasire88's Avatar
    Dec 30 2013
    2005 A4 Quattro, 2001 b5 A4, 1999 b5 a4
    indiana
    Your first order of business sir is to check your engine codes and post them here.
    May 03 2015
    United States
    Quote Originally Posted by mmasire88 View Post
    Hey thanks it was loose wiring and dirty maf and ect and plugs
