Results 1 to 2 of 2
    Active Member Two Rings Sebass26's Avatar
    Jan 05 2015
    Miami /Florida /usa
    Audi B8 A4 P0299 low boost code
    I was pushing my car hard when at about 5400 rpms I got a check engine light which had a code that read low boost. I did some research and found that there are three possible causes to this code
    1. Dirty or bad MFA sensor
    2. Bad or leaking diverter value
    3. A faulty wastegate
    My car right now is running a Revo stage 2 tune 034motorsport HFC
    AWE intercooler
    k&n cold air intake
    forge BOV spacer
    So my question is has this happened to any other B8 owners and could it possibly be the stock diverter value cannot hold the boost pressure that is made when getting a Revo stage 2 tune (-300 hp more like 285 on 93 Oct) haven't dynoed it yet.
    Note : if the diverter value leaking is the issue then I am considering buying the Forge diverter value kit
    Is this a good idea ?
    http://www.uspmotorsports.com/Engine/Forced-Induction/Diverter-Valves/Forge-2.0T-Diverter-Valve-Polished.html?gdffi=0622e703bdae4ba6b8745ab328720f 03&gdfms=E8E46ED65B074AB38A61A089D6A911B3&gclid=Cj 0KEQjwgJq-BRCFqcLW8_DU9agBEiQAz8Koh76sEL2hbitqCpXJOEqWUHy5JF ZKpGrWkxndvul7p_4aApt08P8HAQ
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Check boost sensor. Any sounds of rushing air at all? Has the car had its k03 wastegate recall done?
