2001 Audi S4 Low mileage EXCELLENT condition Stage 3
2001 Audi S4
6 speed manual
Clean title and Carfax
102,xxx miles
Current daily driver
2nd owner (engineer owned and meticulously maintained)
Car looks completely stock/OEM inside and out
Stage 3
Fresh Michelin Pilot Supersport tires (about 6 months of use)
Timing belt, water pump, spark plugs, valve cover gasket service performed at 80k
Drilled brake rotors with ceramic pads installed at 80k
Cluster LCD replaced at 80k
Frankenturbos, 550cc injectors, upgraded side mount intercoolers installed at 80k
Clutchmasters FX300 clutch w/ JHM shift linkage installed at 80k
Noisy front CV axle replaced at 85k
N75 and diverter valves upgraded (OEM) at 85k
Coolant temp sensor and hose replaced at 95k
All shocks and front control arms & bushings replaced at 95k
Stainless steel downpipes and exhaust (quiet & no drone with twin mufflers) installed at 95k
034 2.0T ignition coil conversion + Bosch Sidefire plugs performed at 95k
Transmission and differential fluids replaced at 95k
Rear differential axle seals replaced at 95k
Drives beautifully (~22mpg combined if driven conservatively)
Mobil 1 0w40 Synthetic every 5,000mi
German VDO analog boost gauge
No warning lights
Audi Sport all-weather floormats
Bose amplifier replaced with JL 5-channel
Bose speakers replaced with Focal
OEM Audi Symphony head unit
OEM wheels
Moonroof
Perfect interior, no tears, rips or stains, everything works
Recently smogged
Have original dealer paperwork, spare key, full size spare tire, Audi tool kit, jack, safety triangle, cargo net, repair and maintenance records
Nobody believes this car is 15+ years old
All major and minor services have been performed for the last 3 years I have owned this vehicle and by the previous owner. You will not find a cleaner or more tasteful Stage 3 B5 S4, period. I am looking to start my next car project, but am in no rush to sell. This car deserves to go to someone who will appreciate it as much as I have.
Images located at http://sfbay.craigslist.org/sby/cto/5760049645.html
List Date: 8/31/2016
For more info, click here to view the original listing: 2001 Audi S4 Low mileage EXCELLENT condition Stage 3
This item is no longer available.
