Long story short, my Gates timing belt decided to shear about 10" of teeth off with ~45k miles on it about a month ago. Got the head off and had it rebuilt with newer exhaust valves. I get all parts needed (gaskets, misc hardware etc) together and start putting it back together yesterday. Get the head on with a new head gasket, new cylinder bolts, valve cover on with new gaskets there as well. Everything is going smoothly yet slow. Getting ready to put the timing belt on and check the timing on the head, and it's timed correctly with the notch in the cam gear in line with the casting mark on the head. Go to check the crank pulley [the one that interfaces with the timing belt (TB), not the serpentine belt (SB)] and remember that I had pulled the accessory pulley (SB) off to get the old belt out. The accessory/serpentine pulley (SB) that is bolted to the crank pulley (TB) holds the correct timing mark. It's off the engine at the moment. I get to looking and noticed I marked the crank pulley (TB) with a sharpie from the last time I did this. I also just found a post from OldGuy that shows a dimple on the crank pulley (TB) that aligns with another mark. Good news, I can reference TDC from both these marks, in conjunction with throwing something in cylinder 1 to visually see TDC correct?
My question is, can I turn the crank pulley (TB) without the pistons kissing the valves to get it correctly timed? Or have I made a critical mistake and now need to take the head off again and set the piston timing via the crank pulley (TB) first, with the head off, and then put the head on and finally the timing belt?
