Results 1 to 13 of 13
    Dec 27 2011
    Water leaking out of floor vent?
    I have water leaking out of ONLY the right rear floor vent... Any ideas? 2010 Audi a4.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Well if its clean water the only way is from the sunroof.Could be clogged.
    Veteran Member Three Rings BarEaterB8's Avatar
    Nov 13 2011
    2009 B8 A4 - 1985 Porsche 911 - 2016 BMW M2
    Sounds like it is clogged sunroof drain tubes
    Dec 27 2011
    How would the sunroof drain come out of the floor vent? Doesn't the line go from the pilers down the side and out the wheel well? I put a zip lock bag around the floor vent and it's 100% coming directly out of the floor vent. How would it be leaking directly into the floor vent do the two go side by side at some point?
    Dec 27 2011
    Also, where is the water piling up at? It's been a week since it rained here and the water is still coming out when I drive. Does anyone have a layout diagram of the floor vent relative to the sunroof drains? This makes no sense.
    Sep 02 2008
    Check your front cowl vent drain if you do not think its coming from clogged sunroof drain.If its clean water has to be those two locations.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by vexious View Post
    Best I know of off the top of my head. If you look closely, you can get a relative idea of where the hose runs.
    http://workshop-manuals.com/audi/a4_...ce_and_repair/
    As @ducati stated, it can really only come from the sunroof drain or the cowl vent near your rain tray.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Dec 27 2011
    I just don't understand how it's getting into an AC vent... lol. I'd understand if it was leaking down the side piler or from the top of the ceiling, but draining right out of the vent is so bizarre and only the one... Any instructions on checking the front cowl vent drain?
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    If the weather has been dry and you haven't been washing the car, the only other potential source of clean water I can think of would be condensate from the AC evaporator. There are drain tubes that run from the bottom of the evaporator housing and exit somewhere under the console. I'm not sure if there is one or two tubes and can't tell you where they exit. If the drain is plugged, it's possible the condensate is finding it's way into the vent pipes and running to the rear. If you live in a humid area and have been running the AC for lengthy periods, it will produce quite a bit of water.
    I've been searching for the location of the drain so that I can run a cleaning solution tube up to the evaporator, but can't find anything for the B8.
    2011 A4 Avant
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by jfo View Post
    Use the navigation links in the left hand toolbar for the expanded menu tree; your next click to go through the tech bulletin should be on "Page 9237".
    http://workshop-manuals.com/audi/a4_...n_tube/871118/
    According to this online manual, the drain tubes are "left and right on the air conditioner or the central tunnel"
    http://workshop-manuals.com/audi/a4_...ins/page_9240/
    EDIT: I just noticed this says the "right REAR floor vent". I'll dig.
    °2011 A4 | 6MT
    Nov 17 2010
    Here's some info on the drain tubes. It does sound like this is your issue.
    https://www.scribd.com/document/2915...HVAC-Drain-pdf
    2011 A4 Avant
    Dec 27 2011
    I just recalled -- I had this done 2 years ago! What are the odds the drain got damaged again? Perhaps they never did the work? What are my rights since I had this issue occur under warranty and now it's happening again?
    Oct 23 2014
    Buffalo, NY
    It all depends on who completed the work, and if there were any revisions, recalls, or TSBs for this issue. Generally speaking, a dealer warranty is 12 months/12,000 miles. With that said, I am a firm believer that it never hurts to ask, because the worst that could be said is no. Would you entertain doing it yourself?
    °2011 A4 | 6MT
