Results 1 to 4 of 4
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    B8.5 DRL color temperature?
    Did some searching but only was able to find references to the B8 DRL temp - roughly 5500K. on my B8.5, the DRLs look more on the purple side. Anyone know the actually color temp?
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Roughly 5500k. Our DRL is not that blue compare to facelifted a6/a7 or mercs
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Sep 20 2006
    MD
    Quote Originally Posted by yjypm View Post
    I dropped in some 5500K LED fog lamps and they closely match the OEM headlights but do not match the DRL (the LED outlining the headlamp assembly). I'm looking to match the headlamp LED, not the headlight bulbs.
    Oct 08 2015
    Quote Originally Posted by RLB6 View Post
    Well I can only say that if you get 6000k fog lamps they are more blueish than DRLs.
    Probably 5800k? Because 5800k is the temperature for Audi full led headlamps on the a6
    Current: '18 M3 ZCP
