Hi everyone
Unfortunately got involved in a small accident last week and insurance has decided not to fix my allroad and so has decided to call it a total loss.
Minor front passenger damage it can all be fixed with bolt on, no paint needed if you can find parts. Hood, headlight, radiator, maybe the support although it's ok for now, and some buffing and fixing of the front bumper or a used bumper if you really wanted. It's all fixable and for cheap if you source used parts, I don't have the time.
It runs and drives completely fine but will need the radiator to drive away otherwise a tow. Open to reasonable offers. I don't want to part it out it can be fixed and enjoyed. Posting this here now it will take a bit to receive the salvage title I assume.
I am located in killington VT and the car is close by at my shop.
2004 2.7t with 6 speed (not a swap)
Cobalt blue w beige interior
205k
Stacks of receipts and two sets of keys
In very good shape for a NE car
Within last 5k miles:
Brakes all around rotors and pads
Just completely swapped air suspension 1k miles ago for BC coilovers recoded Ecu no dash lights done correctly these will stay on the car for right price
Timing belt, water pump, rollers, tensioner etc and coolant flush
Serpentine belt also
Plugs just changed
Valve cover gaskets
710n DVs
Oil change less then 300 miles ago w Mobil 1 and oem filter
New front axles
Other stuff I'm forgetting
I bought the car with 196k on it from an older couple and planned to keep it for the long haul, until this unfortunately happened. So all of this work has been completed since April-may. The motor is in great shape turbos make no noise and the car is stock besides the DVs and a catback which I will probably be keeping. Will come on winter wheels w good winter tires, one season on them.
I can send pictures via email or text. As I said I will consider all offers. I can tell you I won't take 500$ so don't ask, I can part it out if I need to but it's really more worth it for someone to fix and maybe go stage 3. :)
Call or text 401 419 6887
Email [email protected]
