Results 1 to 7 of 7
    Active Member One Ring patf0's Avatar
    Feb 18 2014
    South Yorkshire
    Dash shows all 4 doors open, no interior lights, hazards flashing.
    Hi,
    This is happening fairly regularly, every few weeks. The garage replaces a fuse I believe each time. A grinding door motor was replaced which was thought to be the cause but no joy. Car is an A6 C5 Avant 1.9TDI PD130 AWX.
    Any suggestions what it could be?
    Thanks.
    Sent from my GT-N7100 using Tapatalk
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Quote Originally Posted by patf0 View Post
    Hi,
    Thanks.
    On mine it was doing some weird hazard flashing when you sometimes put on the indicator and it turned out to be the Hazard light switch. I wonder if this could be the same with different symptoms... Not so sure about the doors showing open though...
    Sorry couldn't be more help, but the hazard switch is not that expensive if you want to give it a try.
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Mar 14 2014
    North Texas
    footwell light switch under the seat?
    __________________________________________________ ____________________________
    2003 Avant 1.8T 5spd - Silver / Motoza Stage 1+ w/ 550 injectors / Valeo HD clutch kit
    Koni FSD + Hotchkis Sways / 034 snub bracket and mounts / USP lower
    2005 Allroad 2.7T 6spd - Atlas Gray / Motoza Stage 1 / Hotchkis Sways / BC Racing coilovers
    Feb 18 2014
    South Yorkshire
    Thanks guys I'll explore those suggestions.
    Feb 18 2014
    South Yorkshire
    Hi guys,
    I have an update.
    Garage checked the convenience unit, under foot well apparently? This was ok and no corrosion. After this they thought the motor in the passenger door was shorting and causing the issue, so this was replaced, and didn't solve it. Then a 5amp fuse was replaced in the fuse box as it should have been 10amp, still no joy!
    Any ideas on this one?
    It seems to happen when locking/unlocking with the keyfob.
    I have attached a pic of the fuses in case this helps. I think the fuse replaced was 3rd row down 3rd across but I'm not 100%.
    Feb 18 2014
    South Yorkshire
    Does anyone have a diagram of all the fuse locations and numbers?
    Feb 18 2014
    South Yorkshire
    It's fuse 14 by the way, 3 across, 3 down from the top left.
