Results 1 to 10 of 10
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    AT MT Downpipe/Flexpipe
    Has anyone ever used an AT downpipe (after Cat) on a 6 speed? The brackets are different so I'll have to bolt it up without using the support bracket. I'm not sure what will be the side effects to doing this, especially in installation.
    Sent from my LG-H811 using Tapatalk
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Aug 26 2005
    The transmission interferes with Auto down pipe that is why the auto trans and the manual trans use different down pipes.
    Vorsprung durch Technik
    Oct 10 2015
    Detroit, MI
    So not only can I not use the mount but the trans will stop me from installing it any way?
    Jan 06 2009
    Manual downpipe won't work on an automatic because of the larger auto trans. An auto downpipe might work on a manual.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Oct 10 2015
    Detroit, MI
    Only issue I was thinking is that that support bracket helps for mounting it to the cat & center pipe. Also even if you do get it installed on bumps & vibrations will it matter there's nothing to help the flex pipe?
    Jan 06 2009
    Without the DP connected to the trans your flex pipe will tear very quickly.
    B7 2.0t
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by ADCS View Post
    This. Keep in mind that the entire driveline and exhaust system vibrates when the car is in operation.
    I ran a manual downpipe on my automatic for a while without the downpipe secured at the tranny, and it eventually broke right at the turbo.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jun 27 2011
    I've got an old OEM 6-speed DP sitting in my basement if you want it. but shipping is going to be a pain. Just get this Bosal pipe, its OEM for super cheap:
    https://www.amazon.com/gp/product/B0049B0ZCO
    Thats for a 6-speed 1.8t. Installed one in my old b6 and it fit perfectly.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 10 2015
    Detroit, MI
    I posted this after the fact but I had a guy trying to sell me a used AT DP for $50 I was really close to getting. Then an ebay seller selling an almost new AT DP for $75, everyone was telling me just use it without the bracket if the bracket isn't compatible. Then I noticed the diff in the support mount and posted WTBs on all FB groups, forums, and checked part outs on Craigslist for 6 speed DP. Finally checked RockAuto and saw the Bosal for $85, went back and forth in thinking maybe I should get the cheapest solution since I'll do a cat back system next year. Then I started to think about what's the bracket's function and deciced to pay $50 (expedited shipping) more to get the Bosal. Just for shits I decided to post this to ease my mind & confirm....thanx guys!
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    When I converted my five speed to a six speed, I made a short bracket to adapt the down pipe to the new transmission. It seems reasonable that an AT DP would fit, since the AT is huge compared to the six speed. That does seem to say that the adaptor bracket might be a bit larger.
