Hi, I'm at a loss, and could really use some help. This car had a used engine swapped into it and came to me running in limp mode with the Maf sensor connector disconnected.
After replacing a few parts, I have alleviated a few codes I was getting, but the car still will not run properly.
I was originally getting P0008 and a Maf sensor code and one other that I can't recall now. I replaced the hpfp, low fuel pressure sensor.
I now get no codes with the Maf sensor connected, but the engine tries to stall in idle roughly every 5 seconds, surges to recover, then returns briefly to idle ~800-900 rpm. Then it repeats. Occasionally it'll stall completely.
I get no codes now, I'm so frustrated with my first Audi experience! Please help if you can.
Thanks,
Jon
