Results 1 to 7 of 7
    Established Member Two Rings kstaack's Avatar
    Feb 02 2015
    Madison, WI
    Data Log - Underboost: Stage 2 HPFP
    Hello!
    I have recently tuned my car to Unitronic Stage 2 HPFP, and I am not getting the power and boost I would have expected. I am not here to discuss different tunes, but I want to know what could be causing this underboost. I have read plenty about the waste gate issue that others are having, but I am not entirely sure if this is the problem. I am hearing a whistling sound when I am WOT... Also, I am not getting any codes for underboost.
    Here is my car:
    I have owned the car since 127,000 miles and its at 170,000 miles, and I have never done anything with the turbo/wastegate and the N75. I have replaced the DV, timing belt, water pump, timing chain, vacuum pump, HPFP, Autotech HPFP internal, catless downpipe w/ o2 spacer , PCV, charcoal canister bypass, purge valve, and I think that is it for motor and emission work. Here is the data log from my vagcom:
    I would love to here what everyone has to say. This is a 2008 tip s-line with r8 reps, 18z, rs6 grill, H&R coilovers, 034 rear sway bar and end links, led conversion, and I am sure there is plenty I have forgotten.
    Sorry for the long winded post, but I appreciate all the help!
    Oct 24 2015
    Perth, WA
    DV needs replacement probably.
    My respray thread
    Feb 02 2015
    Madison, WI
    I replaced it about two months ago before the tune
    Oct 24 2015
    Perth, WA
    Then you have a leak elsewhere, need to used some soapy water to detect where it is coming from possible.
    My respray thread
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Problem with the tune... talk to the tuner, simple.
    Should be boosting around 18psi.
    Oct 24 2015
    Perth, WA
    Unless there is a leak of course. Given there is a whistling noise, id back that idea.
    My respray thread
    Feb 02 2015
    Madison, WI
    I do not think there is anything wrong with the tune. It peaked at a specified boost pressure of 2440 mbar
