Results 1 to 7 of 7
    Dec 20 2015
    Reverse does not fully engage, pops out.
    Let me first say I have adjusted my shifter probably 100 times over the last four months with an angle gauge.
    I have difficulty going into reverse fully(the reverse lights will flicker off and on as you are backing up) and will pop out almost daily, I can force the shifter up 4-5 times and it usually stays in.
    6th gear feels similarly half engaged, but most adjustments I have done 6th does not pop out. Every other gear shifts great.
    Who has had this issue and rebuilding or upgrading to solid shift linkage solved it, or didn't solve it? It is not easy or cheap to do and my shifter doesn't feel overly worn.
    Is it worth the time and effort to just replace the plastic ball and socket repair kit on the trans, or should everything be upgraded if apart?
    This post by scotty states the reverse detent can wear out, is this a detent that is accessible while repairing the linkage?
    http://www.audizine.com/forum/showth...=1#post8740180
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Make sure the 13mm nut that holds the lever on the side of the trans it tight.
    If it has ever been off, people sometime like to lose the wedge inside that locks it in place. Nut will def loosen up it it is missing.
    Try loosening the top center bolt and sliding the plastic shifter box thing backward a lil before retightening.
    This should give you a bit more forward throw before the shifter ball or linkage binds. (leave the angle gauge in the toolbox and dont touch the lower bolt)
    A short shifter would prob help, but dont mess with the linkage stuff. Maybe replace the socket thing on the trans if you are feeling brave, I usually do them when trans is out.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Is your current shifter linkage completely stock? The reason I ask, is that if it was upgraded to JHM's solid linkage, then there is a warning about having to cut/modify the linkage rod at https://jhmotorsports.com/products/p...l_Assembly.JPG. Years ago, when I had a shop install the solid linkage during an engine pull, they weren't aware of the need to cut/modify the linkage, and my car kept popping out of reverse, so I took it up to JHM, and they found and corrected the issue. I'm not sure if 6th gear would be affected by this, plus I'm not sure what would cause it if your shift linkage is stock, but just wanted to mention the possibility.
    PS - there is also some good adjustment info at step 9 of the install section at http://www.audiworld.com/tech/misc47.shtml. I also remember a warning somewhere that it is always possible to install the shifter 180 degrees out, but I believe in that case, you won't be able to get reverse at all. - Jim
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    What shifter do you have? When you put it in reverse does it stay in position but pops up?
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Established Member Two Rings sxC's Avatar
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Can confirm, with the JHM shifter and linkage if you do not have the linkage rod shaved/cut down it will not go into reverse or 5th/6th. All the other gears will feel normal.
    This exact thing happened to me just a few months ago.
    Nov 16 2010
    WetSide, WA
    That jhm solid linkage thing is badass, but you better eat yr wheaties
    Dec 20 2015
    Yea all stock, I bought it with a blown motor, blown turbos, ripped seats, everything was factory, just driven until dead, but nice paint somehow. I did the motor swap so I got a good look at the trans while apart, I wish I knew it had a problem before...
    Anyone else know about that installing something 180 degrees out?
