    Aug 16 2016
    P0299 Underboost code - diverter valve?
    Hello all,
    My first post so here's a little background. Just became the owner of a 2012 A5. I'm experiencing a couple problems: 1) the car doesn't seem to want to really boost until about 3500-4k. 2) the previous owner installed a AWE diverter valve. 3) there's a check engine light #P0299 for turbo underboost.
    Now, here's my guess. The diverter valve is making a loud blowing noise everything I release the gas (I thought it had a BOV all this time...). Could a torn DV be the culprit for all the above? For what it matters, the car is also running an AWE exhaust and Injen cold air intake.
    Thank you in advance and yes, I know that there are a post or two that are similar but please help me here nonetheless.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    it is possible that its the Diverter valve, but a dirty maf if you are running an oiled filter can also cause it. if you want to go cheap first(DV's are too bad if you go oem) get some maf cleaner and make sure thats all good, then jump on the DV. I had the same issue replaced the DV and still was getting the error, cleaned the MAF and nothing since, I use a K&N Oiled filter in my B8A4.
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Aug 16 2016
    Thank you for the advice guys. I wish there was a more specific code... everything is such a puzzle in this car.
    Sep 27 2015
    OH
    had the same code swapped out the dv and everything seems to be good no codes so far
