Intercooler upgrade complete Thanks Hofahome!
Went Flat black on the brackets. I also elected to use 2x 90 degree pieces instead of 4 and bolted the cooler to the brackets instead of using the studs on the intercooler.
Gloss black touchup on the bumper support and mounting bolts.
System took almost an additional gallon of coolant and appears to double the available surface area.
I elected to keep my system divorced...the rationale is that the thermostat and the water pump will keep the engine at operating temperature. I'd like my supercharger to run cooler than the engine. By leaving them married, your charger coolant will eventually match the engine coolant temperature...negating the potential benefits and supported by APR research.
I also reset my coolant pump back to the PWM configuration for now. There is more volume to push around, don't want to overwork that pump until I have more time to experiment. I was originally going to wire in a switch...but lost interest in pushing wires through the firewall.
Also re-installed my KI 194 mm crank pulley. I was one of the original purchasers that did not receive a pulley with the offset hole. As a result, it was not perfectly aligned and the charger would squeal if I didn't run a 6-rib belt on the outward ribs. The misalignment was not very visible but a problem none the less. I pulled and drilled a slightly larger hole, then reinstalled...alignment fixed. While I was in there, I replaced the serpentine belt, supercharger roller, supercharger belt and tensioner. I should be maintenance free for a while.
