Results 1 to 10 of 10
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Suction jet pump (vac) noise?
    Alright, my crank breather was cracked, the whole PCV system was thick with sludge, it was original. So yesterday I replaced the elbow off the crankcase / filter housing, the tee with PCV in it (and the PCV), and the suction pump. I desludged the metal pipe on the way up to the valve cover. Some sick bastard routed the vacuum system on this thing. I've got so many wounds...
    Anyhow, I'm missing a few clamps (just for today until I can get them) so that might be it, but I hear a whistling from the SJP area now. If I pinch off the line between the pump and the intake, it quiets, so that is certainly the cause. But I'm wondering - does a normally functioning SJP whistle a bit? I'd kinda think the venturi thing might do that. But maybe I just have a vac leak.
    Aug 19 2013
    minnesota
    No Audi owners are typically pretty pretentious and expectant. A whistling sound from the motor would not be allowed. The only thing that really can be described to whistle would be the turbo. Sometimes when you're boosting you might hear a little bit of a high frequency turbo sound.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 15 2016
    Western Canada
    It's a very faint air rushing sound, and pressing all the hose ends around the SJP doesn't seem to change it. only pinching the vac input to manifold part does, but I guess i must have a leak somewhere..
    Aug 19 2013
    minnesota
    Inspect the hoses, your conclusion will be reached if you hunt it down. But it's normally a pretty silent functioning set up.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Leak.
    2019 SQ5 Prestige
    Aug 19 2013
    minnesota
    I notice the suction jet pump makes a thhhhh sound.
    Aug 26 2005
    Is the noise most noticeable at idle speed? That is when the intake manifold vacuum is highest.
    Vorsprung durch Technik
    Aug 15 2016
    Western Canada
    Yeah, I can only hear it at idle, and even then it is hard to hear over the engine.
    I put on some more clamps, and still hear it. Pinching either the output (to manifold) or input (from PCV) make it quiet so I think it must just be the venturi internal noise. neat.
    I was going to use a stethoscope to narrow where exactly it is but I couldn't find the darn thing.
    Oct 07 2008
    05’ GLI 1.8T_4motion, 07’ A4 3.2_quattro
    Calgary, AB.
    I’ve had brand a new suction jet pump leak... took me a bit to figure it out since it was new and I assumed it was good but when I sealed my hand around the one end, the noise of moving air went away. Replaced it (again) and the leak dissapeared.
    Aug 15 2016
    Western Canada
    Hmm I did wrap my hands around it quite a bit with no change (and on every hose in the area).
    It was a dumpster-grade 'mtc' one I had in the parts heap from my golf, so maybe it's just bad out of the box.
