Results 1 to 1 of 1
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    ::Excelerate Performance:: IS38 Turbo Packages
    Excelerate Performance announces bolt on IS38 turbo package for the MK7/8V Audi/Volkswagen platforms.
    Using either OEM or APR hardware, Excelerate Performance has made bundles and packages to make shopping easy. As most know the IS38 turbo is quite the upgrade for the IS20 Turbo Driven platforms. Cars are capable of seeing upwards of 386 HP gains
    on just 93 octane pump fuel. This turbo is factory on MK7 Golf R and 8V S3 platforms in the US and is a direct bolt on for the MK7 GTI and Audi A3. Along with these hardware packages there are some additional pieces to this puzzle that come highly recommended. They can be seen at the end of the core information.
    IS38 Turbo Packages
    Package 1
    IS38 Turbo plus install kit
    $1,475
    Package 2
    IS38 turbo plus install kit
    APR intake
    $1,900
    Package 3
    APR downpipe
    $2,200
    Package 4
    APR intake
    APR downpipe
    $2,625
    **APR IS38 Software can be provided to local customers contact us for pricing**
    We are also offering labor incentives to local customers for installation.
    EXTRA RECOMMENDATIONS
    Spark plugs
    Excelerate Performance highly recommend replacing the factory plugs per
    APR's recommendation. Using a Denso IKH24 gapped to .024 seems to do
    the trick very well. This gives you the security when running higher boost to
    make sure you rule out chance of misfire conditions.
    Denso IKH24
    Clutch
    The stock clutch in the MK7 leaves a lot left to be desired in even factory trim.
    When you start to make more power slippage becomes more of a worry. With the power levels gained from this upgrade we
    recommend replacing the clutch disc and pressure plate a minimum to avoid slippage.
    We have a few bolt on solutions while retaining the DMF but we highly recommend the South Bend stage 3
    endurance clutch upgrade for all non DSG vehicles.
    For DSG vehicles, APR DSG software is HIGHLY recommended as a supporting modification
    to this upgrade. You can find this hardware below on our web store and local customers can always stop by for flashes
    here
    Contact us for shipping quotes to the Continental lower 48 states.
    If you would like to know more either call
    203-483-6100
    E-Mail
    [email protected]
    To view these or other items visit our web store
    http://vag.excelerateperformance.com/
    Check Us Out on Social Media!
    [/CENTER]
