Results 1 to 11 of 11
    Aug 06 2016
    2005 Honda Accord V6
    Louisville, KY
    Interesting discovery related to high oil consumption
    I bought a 2005 S4 Dolphin Gray Cab in January with 78,000 miles
    I love my S4, but they sure are maintenance hungry. One of the more interesting problems that I got was a low oil light on within 500-1000 miles every time, sometimes a lot less. Eventually, a red flashing "Low Oil Pressure" light came on to warn me of my engine's near-death. Then it went off. Then back on. Then off. All in the matter of seconds. Keeping the oil topped off sometimes kept red oil pressure light away, but it always came back very quickly, and interestingly as well, restarting the engine sent the light away until i started driving. Or so I thought, when trying to determine was was triggering this low oil pressure light when finally resolving the issue, I found that it went off everytime the car accelerated to 2200rpm or higher, and would usually stay on at the point. Decided it was time to pull the sensor and replace it. $7 later on a VW/Audi oil pressure sensor from ebay, i pull off the old sensor to find it covered in oil and disgusting. Replace it, boom, car fixed, runs fine. Now, nearly 10k miles later, i have added a quart of oil to my car maybe 2 times over those 10k miles. I figured my engine was almost gone from cylinder scoring but now I'm hopeful I might have a survivor.
    Sensor replaced: 82500
    Current Mileage: 91005.
    Moral of the story:
    The oil pressure sensor can leak very significant amounts of oil, therefore making it seem that your engines are burning more oil than they actually are. This part is worth glancing at/replacing to help reduce oil loss on all high mileage high oil consuming engines.
    Feb 06 2012
    B6 S4, '97 4Runner, '18 4Runner TRD PRO
    MD
    Was the oil actually low when you added some to make the light go away? Are you saying that sensor lowered your oil consumption? Just trying to understand cause I'd love to solve mine burning a qt/1200 mi. Thanks
    Sent from my SM-G935V using Tapatalk
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    replacing a sensor is NOT going to fix oil consumption issues. you had a failing sensor, thats one separate issue. If you are adding 2 quarts of oil in 10k miles, you still have oil consumption.
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    this post makes no sense in regards to oil consumption. Are you sure the sensor wasn't dripping oil or something of that nature. again there is no way the OPS will cause you to consume that much oil
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Aug 06 2016
    Louisville, KY
    Quote Originally Posted by jmcS4 View Post
    This is exactly what I'm saying. I'm sorry for the improper wording it seems but don't all gang up on me here because I dont have a miracle solution for you. All i am saying is that YOUR OPS may be leaking oil, contributing to your overall engine's consumption. This was what was going on in my case, and I am saying it is a very cheap very easy service that *may* reduce your oil consumption as well. Sorry for trying to help everyone!
    Aug 06 2016
    Louisville, KY
    Quote Originally Posted by AudiSport90 View Post
    Yes, exactly. the sensor itself was the source of nearly all of my engine's oil consumption because it was leaking oil out of it very rapidly, but the oil only leaked while the engine is running so i never noticed any puddles anywhere from this.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Thanks for the clarification.. your OP was definitely confusing lol. Makes sense now.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Nov 16 2013
    Lower NH
    Quote Originally Posted by Mitchelperkins View Post
    theres probably a giant puddle on your transmission or the exhaust is burning it up. it did leak when the car was off because theres not pressure at the switch and the oil goes back in the pan
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    *Car no longer leaks oil but has started to sweat power*
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Good catch perkins.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Def worth an inspection! Thanks for posting this.
