Hello everyone out there,
I truly need help and advice from everyone and anyone who can tell me or give me an advice on running Vossen vfs1 wheel with the size of 19x9.5 et40!
I've got the Vossen wheels and I've got the tires which in 235/35/19 continental contisportcontact 5p
Today I went to the workshop to have them fit those wheels for me and they did a trial on the rear wheel by just putting the wheels without the tire mount on it yet since the guy at the workshop reckon those wheel will not fit the car!!
And I told the guy that I've seen a few people with the same car and are running on the same Vossen wheel with the same offset and size!
So they went ahead to do the fitting trial and everything goes smoothly until the wheel was actually very close to the rear shock! Which the guy said, once the wheel and tire mounted and have the bolt tighten them, it'll definitely rub against the shock and in worst case the wheel will be ruin and it probably won't even move!
So if anybody out there that can help me or have already running this set up without issue please tell me how did you guys managed and is there such trick or some type of fact that needs to be acknowledge before fitting these wheels on.
My car is a 2014 Audi A3 Quattro S-line 1.8TFSI 8V which is identical to an S3 except the size of the engine. So please can someone explain why do I have this issue? And btw my car is running on stock height as I want to see what sort of clearance I have got left after fitting those wheels before going ahead to choose what sort of set up height I want.
I be really appreciate it if someone with a great knowledge can help me out of this as I've bought all of these things but only to find out it doesn't fit onto the car:(
