Results 1 to 33 of 33
    May 09 2012
    Virginia
    Remote custom tuning
    I am in a Audi performance desert oasis. I am looking for custom tuning in the Virginia (Richmond) area. Ideally I would like to do this remotely with data logs, but am willing to travel several hours. I am not in a position to mess around with Maestro or something similar at this point as I don't have the time.
    I am coming from the B5 world where there were a number of options for this. I haven't had much success for the B7.
    Any input appreciated. Thanks.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Well, on the plus side, you're only 3 hours away from RAI.....
    I'm pretty sure they teamed up with eurodyne some time ago so any tweaks you need to do you will be able to change that later on. Nothing beats an in house tune with pros doing the work.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    May 09 2012
    Virginia
    Quote Originally Posted by Denio24 View Post
    Most of the feedback I have seen regarding RAI is not the inspiring.
    Jan 23 2013
    Chicago
    Quote Originally Posted by jbain2 View Post
    Dang maybe things went downhill. I remember seeing good things about them right around the time i joined the forum.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    JHM sells a cable to tune your own car. I have the cable I rent out if you end up doing that route. PM me for details. PS JHM tune is beasty.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Quote Originally Posted by yeoj112689 View Post
    JHM only provides custom tunes if you leave the car with them
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by derrek View Post
    Ahh I didn't read it correctly. Well if you want custom I am not sure but JHM's stage 2 93 oct is awesome :D
    May 09 2012
    Virginia
    I may have to go the route of eurodyne or maestro. The notion interests me, but I am not sure of the time commitment to do it properly. I am running a GT series turbo, meth and I.E. rods.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    What's your ecu part number? Most of the leg work for you to custom tune , has already been laid out . If you take the time to learn it , you will be set for life.
    Sent from my 831C using Tapatalk
    May 09 2012
    Virginia
    Edit: not sure why the double post. I think a big issue is that I am running an old GIAC file and I am not sure it can be overwritten. I have a second ECU that I am hoping to clone but I have to get the original ECU back to stock.
    May 09 2012
    Virginia
    Quote Originally Posted by turbo944s2 View Post
    Eurodyne or Maestro? ECU part # is 8E1910115G
    Sent from my VK810 4G using Tapatalk
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Eric from here already has a definition file laid out on nefmoto for your ecu. He has all of the addresses laid out for you. The instructions on how to clone the ecu are there also. There are also stock files to, overwrite your current file. I suggest you make a copy of your giac file first , since you paid for it.
    Jul 23 2010
    arizona
    I'd stay away from maestro. Ask some of the b5 tuners if they've messed with the med9 ecus before or find someone who knows WINOLS.
    Dec 23 2011
    Maestro is decent. It won't be like a custom tune but I don't get all the hate for that program. Documentation sucks and you'll need a lot of background info but the program itself is fine and will get you 95% of the way there. My gtx setup runs fine at this point.
    Mar 24 2013
    Oakdale, CT
    My kor ran great on maestro after i figured it out. Check out UM, I think they may do remote tuning.
    -Adam
    May 09 2012
    Virginia
    I contacted UM. Thanks.
    Jun 17 2013
    jersey city nj
    I contacted UM.
    option
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    I remote tune Maestro, PM me up if you want to chat.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Mar 08 2011
    2006 A4b7, 2013 Q5 TDI, KTM 1290 SA
    San Jose Costa Rica
    Adam what is your ECU pn for the A4 your did with the K04? i am getting no where fast with Motoza trying to get this done has become linger then the rebuild. I am thinking since my car is 95% same as yours i might be ahead to try the maestro route if i can get simple to follow instructions.
    thanks
    rick
    ps being in CR has convinced me to just buy an M3 next time or similar and forget this effort in the future.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by rickescazu View Post
    thanks
    rick
    I had a 115M ecu on that car. I think I still have my files somewhere but I no longer have maestro. If you want, I can send you my last file. It was for a built motor with meth.
    -Adam
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    thanks
    rick
    Why not go with JHM if you have a K04? Just rent or buy their flasher. UM also have a remote flasher. As does Malone tuning I believe. Just other options outside of Maestro.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Dotuning.com?? They still putting out tunes.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    I would look at the Greek guys, Revlimit tuning. If I can't get my car under control, Im going to go with them.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by canadianA4B7 View Post
    On a limited basis, yes. Derrek and I both use DoTuning.
    -Adam
    Feb 10 2012
    parts
    Napanee, ON
    I just spoke to one of the guys in Greece. He said to grab rs4 injectors prior to reaching out to revlimit. I may go this route soon myself. Unless dotuning wants to have a go at it.
    I shud sell maestro and learn ols as you suggested. Or let a pro do the tuning as its not one of my strong suits.
    - - - Updated - - -
    Cud you send me contact info? Or is best way to contact via Facebook?
    May 09 2012
    Virginia
    [COLOR="silver"][SIZE=1]- - - Updated
    I have a set that I would sell if anyone was interested.
    Feb 10 2012
    parts
    Napanee, ON
    Oh do you good sir!!! Humm I shud get the ball rolling on a tuner then! How much u like for these?? Many monies?
    wonder what I cud get for my S3, they've only run 2200km.
    Mar 08 2011
    San Jose Costa Rica
    That would be great but my motor is just ko4, meth, upgraded HPFP, S3 injectors, R8 coilovers, new large FMIC, 3" hi flow cat and SS exhaust, after that is just suspension upgrades. if you did rods and such maybe your tune it to much from my motor? I am not a wiz on vcds i can work it with thought and the guys here have said maestro is very hard. so not sure but seems operator is recommending JHM and UM now as options. i was going to give dave another week as its been 2 months and then if no luck as for a refund and try with maestro or another tuner. my issue is i need to pass emissions here and then revert to a good tune cant come close now as its way rich on stock tune. advice?
    thanks as always.
    Mar 08 2011
    San Jose Costa Rica
    are you familiar with this company and product, seems a lot simpler than maestro. of course i guess you still need advice knowledge etc about changing the parameters on the PC side.
    at least my model motor etc is supported.
    https://www.alientech-tools.com/en/powergate3/
    Feb 10 2012
    parts
    Napanee, ON
    With maestro you can set your emissions readiness yourself. My car passes e test here in Canada every time and has for the last number of years while tuned.
    If your computer savy (which I am not) you should be able to navigate through the programs and do the tuning. Similar to rocket science yes, easy enough myself can use it tuning yes. I hate the computer side of things. Give me a carburator any day of the week I'll get it running efficiently. Me telling a computer to tell a car what to do, well that's just not my thing.
    May 09 2012
    Virginia
    This device is designed to read and write to the ECU. I have one. Someone still has to write the code and do the tuning.
    Mar 08 2011
    San Jose Costa Rica
    Here in Costa Rica they shove a sensor up the tail pipe dont care about ODB port or the gauges or lights just the sniffer. so is that an issue?
    Feb 10 2012
    parts
    Napanee, ON
    All depends on cat then. i wud think? If your cat doesn't remove all it shud the sniffer will fail you.
    Wonder if removing one of the resonators and putting a cheap offshore cat in wud skew the test enough to read a sniffer test pass? Might be a lot of work but cud be beneficial in your case. (This wud envolve some welding and multiple v band clamps. remove able cat pipe mid?)
