Results 1 to 14 of 14
Thread: Minimum oil
    May 20 2015
    Watertown, MA
    Minimum oil
    So I was driving today and a warning came up saying my car has minimum oil and I need to add a quart (1 and a half max). I pulled into auto zone and threw in a quart and a half and everything seems good. What's with the oil consumption on these cars? Is this normal? I think I have put around 3000 miles on this car since I bought it cpo last October.
    Mar 21 2015
    A year and model would help tremendously
    May 20 2015
    Watertown, MA
    2011 s5 v8 37k miles
    Established Member Two Rings Corners4kids's Avatar
    May 11 2016
    2019 Tiguan SEL Prem (wife)
    Centennial, CO
    Minimum oil
    I end up adding about 1qt over each oil change cycle (3000 miles). I did on my RS4 (1-2qts) before this car too. Just part of owning these cars.
    I even bought a dipstick for my S5 so I can see the oil level/quality and don't rely on the electronics to tell me when I'm getting close to add time. $38 from the dealer.
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Minimum oil
    Yep, buy a case-load or three, you'll be needing it over the course of the next few years.
    Senior Member Two Rings rmbrown09's Avatar
    Sep 27 2014
    United States
    I've been trying to determine some oil consumption issues as well. I have had the dealership tell me the oil pan is leaking a little, I need to replace it. Last oil change was 2500 miles ago, and I'm at the halfway point on the MMI bar. Typically need to have the dealer top it off twice in 7-8k oil intervals i run. My consumption compared to a lot of people on here seems to be normal or even better than that. I think if I ever need to top it off 3 times between changes you know something is going on. Or you are just driving the dick out of it.
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    min in about 5K miles.
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    i know the v8 models have had to deal with this for a while now, but I'm curious if any 3.0T guys have been having to deal with this as well? I have a 3.0t and I just got that warning yesterday. I also had the same warning come on a couple months ago before my scheduled maintenance. Oil gets changed every 5k miles. Car has ~60k miles on it now. Mines a 13 model. I've added oil everytime the warning light came on.
    Aug 30 2013
    KY
    Mine needs about 1/2- 1 qt added per year. Same engine.
    SLOWER TRAFFIC KEEP RIGHT
    Established Member Two Rings brunogomes's Avatar
    Apr 21 2015
    New Jersey
    I'm due for service / oil change in like 3k miles and the min oil level add 1/4q max notification came on recently ^.^ (b8.5 s5)
    Active Member One Ring Djsteelo's Avatar
    May 24 2016
    Palm Beach
    I have a 2014 A5 with 14000 mile son it and I got the same message and had to add one quart after 4500 miles.
    Established Member Two Rings Siopao's Avatar
    Aug 22 2016
    2019 A7 2021 Q7 (wifey)
    Houston, TX
    I have a 13 S5 47k on it and i usually need to top of close to the end of the intervals of scheduled maintenance. Not to bad... and i like to think i ride it pretty spirited as well.
    Oct 27 2014
    Park City, UT
    I think some dealers are shorting us on oil too. Had my oil changed and checked it the next day...3/4 full! I'm so glad I prepaid for that type of service lol
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    09 S5 and have never had to add oil
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
