Results 1 to 12 of 12
    Senior Member Three Rings tommy782's Avatar
    Aug 01 2008
    canada
    Another wheel thread
    Hi everyone.
    I read a lot and I also was a B6 member since long time. My friend when to sell me his a4 b7 2007.
    I want to put 19x8.5 wheel and I want to know what is the best tire set up (235-45-19 225-45-19 or 235-35-19)... the offset of the wheel is 40. Someone have this setup?
    What is the feeling on the road?
    I want to put coilover on it at the beginning if I buy it.
    Thanks
    Tommy
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    yes
    Aug 01 2008
    canada
    what is your set up Donaldson and 235-45-19 run smooth and fit good on the fender?
    also I see a kit of Niche M110 circuit 19''x8.5 satin black at 450$ CAD for 4... is a good price?
    thanks,
    tom
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    225/45/19 is probably the most B7 specs on 19's
    I have 235/45/19 on peelers with coilovers and ride is smooth
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Aug 01 2008
    canada
    thanks Copen-cisco, I call the tire dealer and he tell me that the 225 is a standard for the 19''
    Sep 06 2013
    Dublin, CA
    Quote Originally Posted by tommy782 View Post
    That would work fine. I had that one my car before I got 235's
    Kristian
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Hi everyone.
    Thanks
    Tommy
    Is your car lowered? If so, that ET of 40 will be a potential problem, I run a 35 ET and had to use 5mm shims up front with a 245/35/19 Michelin wrapped around VMR 718 wheels on a H&R Sport spring. If you want to run a 40ET plan on using a 10mm shim and 235/35/19. But for help of fitment, go to http://www.willtheyfit.com/ for backspacing. To get your proper stock wheel size, go to http://www.wheel-size.com/size/audi/a4/2007/
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Mar 26 2015
    Hi everyone.
    Thanks
    Tommy
    I have 19x8.5 with 43 offset... I run 15mm spacers front and 17.5mm spacers rear so effective offsets are 28/25.5. 225/35/19 with ST Suspension coilovers and I find it as comfortable as my stock 18" wheels.
    Aug 01 2008
    canada
    Why I need spacer for et40? Can I run 225-45-19 with a 40et without it?
    Aug 01 2008
    canada
    If I use the website to see the fitment its write that I will.be 17.7mm more near to the shock also it tell me.that I have a poke of 7mm...... it will fit.or.not? I will put.coilover but not at the lower setup.... Im going to see the wheel tonight... someone can align me please...
    Aug 01 2008
    canada
    So 10mm or 15mm spacer front and rear?
    cisco, do you use spacer on 225??
    also, I see another kit of 215-40-18 with 8'' et45 at the front and 9'' et40 at the rear.
    I know that isn't 225 or but can this offset/wheel can fit good on the B7?
    Aug 01 2008
    canada
    It was a big difference between 35 or 45 thickness?
