Results 1 to 9 of 9
    Aug 23 2016
    kansas City
    32mm offset on 19x8.5 of B8.5 A4 quattro?
    HI:
    Offset is really confusing me. I am looking at this wheel off an S5. 8t0601025f
    I have a 2013 A4 Quattro. It has 17s, and the offset according to the Audi dealer parts guy is 45mm on my 17s. he said the 32mm may not work or cause issues.
    The 19" wheel is a 19x8.5 with a 255/35R tire. offset is 32mm.
    Will these wheels work and what are the issues with putting a lesser offset on? I searched but could not find anything on the 8.5 A4 with 19s.
    Has anyone done this and had success?
    thx
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quick and dirty offset explanation:
    You know the where the center of the wheel mounts to the wheel hub, that surface (on the back of the wheel) is where offset is measured. Imagine if that surface was pushed further into the depth of the wheel, or pulled further out towards the face of the wheel... that is offset. The very middle of the wheel depth being 0mm.
    With that out of the way, the wheel specs above are well within tolerances and fit without concern.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Aug 23 2016
    kansas City
    Aug 23 2016
    kansas City
    so another issue....lowering. The 19s seem to suffer from the monster truck look and the cars that are lowered look much better.
    Is it only 19s that do this or will 18s need to be lowered as well? I like the look of 19s, but it really seems the hassle factor goes up (offset, height...) and the ever present damage factor.
    Are 18's the way to go? I don't really drive aggressively, I just think the 17s on the car now look ridiculous. IMHO the B8.5 begs for larger wheels.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    The general consensus is lower it or put on OEM sport suspension. Almost any wheel looks like a 4x4 pre-drop.
    My 2009 A4 Prem+ Build thread
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    It's not the wheel diameter that gives your car the 4x4 look.
    Your rolling diameter will not change (much) when switching between 17", 18", or 19" wheels because the tire sidewall should compensate for the difference in wheel diameter.
    The 4x4 effect is really a symptom of the stock ride height suspension combined with an aggressively offset wheel.
    If choosing between suspension or aggressive wheels, I'd choose to do suspension first.
    JMHO
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Jan 10 2007
    VA
    Check out the links below for stock suspension A4s with A5/S5 wheels.
    http://www.audizine.com/forum/showth...e-Feedback-Pls
    http://www.audiforum.ca/a4-b8-typ-8k...s5-rims-70219/
    Aug 23 2016
    kansas City
    Hell, same money as wheels I can get it dropped 1.2 inch all around. Eichbach has a 1.2 front, 1.4 rear kit.
    Any downside to dropping by a spring kit?
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by markstull View Post
    Your shocks will fail in about 10k miles. Do coilovers or the B12 Pro Kit. Or retrofit OE sport suspension if you only want a very mild drop.
    Those wheels will fit just fine though... That's actually a great fitment for sedans. I run 8.5 ET35, which looks great, and a few mm more flush wouldn't be an issue.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
