Results 1 to 11 of 11
    Junior Member Two Rings
    Aug 08 2016
    ohio
    Help with HUD Lap timer
    I was following the procedure:
    Enable Lap Timer Shown in HUD- also enables shift light
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 - Check the box for "Lap Timer active"
    after I hit "load coding helper" I did not see Byte 1. So I could not proceed to Bit 3 and check the box for "lap Timer active". Any help would be greatly appreciated.
    2013 S6 estoril blue
    Previous: 07 A8L
    01 allroad
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Make sure from the main screen you have gone "[Select] -> [17 Instruments] -> [Coding 07] -> [Long code helper]
    From memory when you click [Coding 07] and then the long code helper button, byte 1 is already displayed. Under that should be some check boxes and bit 3 will be one of them. Check it and click do it.
    Correct that: Byte 0 is displayed first, so you need to click the second box in beside the "3)", shown as a green "00" in the example (different screen shown here for example)
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Aug 08 2016
    ohio
    Thank you. I would have never figured that out on my own. I did what you said and now have lap timer working. I will be using this feature in a few weeks. I have my first track day scheduled in a few weeks.
    Previous: 07 A8L
    01 allroad
    Aug 27 2015
    New Zealand
    Glad I could help. The lap timer with boost is my favorite mod, since the HUD shows my current gear, when in this mode.
    Aug 08 2016
    ohio
    Just so I'm sure. Mine only shows the current gear I'm in when I'm in manual shift mode. When it's in "D" I only get the "D" symbol in my HUD.
    Previous: 07 A8L
    01 allroad
    Aug 27 2015
    New Zealand
    There's another option that turns on the current gear display in D and S modes. Here in New Zealand it's enabled by defaults. Here is the option:
    Enable Automatic Gear selection shown in DIS
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    Active Member Two Rings suicidalguitar's Avatar
    Nov 16 2011
    St Moritz
    For some reason I cannot get the lap timer to show up on my DIS menu. I did activate it with VagCom but it's not listed in the menu. It's a 2012 S7 (MY2013). Should it work on every cars or do some cars miss this option?
    I realy don't care much for the lap timer itself, but I'd love to have the gear showing up on the HUD. Do you guys have any tip for me? :)
    Aug 27 2015
    New Zealand
    Quote Originally Posted by suicidalguitar View Post
    Unfortunately some 2012 models cannot enable the lap timer. :(
    http://www.audizine.com/forum/showth...1#post10099281
    Nov 16 2011
    St Moritz
    Quote Originally Posted by MadAboutCars View Post
    That's a shame I really miss the gears in the HUD.
    Thanks for your help :)
    Aug 08 2016
    ohio
    I will try to get the gear selection tonight.
    Previous: 07 A8L
    01 allroad
    Aug 08 2016
    ohio
    Thanks again. It's great knowing what gear your in.
    Previous: 07 A8L
    01 allroad
