Results 1 to 3 of 3
    Aug 16 2016
    Navajo Nation, AZ
    Piston Dimensions
    I'm going to buy an engine rebuild kit and want to know what the difference between standard, .5mm, and 1mm is. Do I just buy Standard size for all the parts associated with the rebuild?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Sep 03 2011
    99.5 A4 Avant Quattro, 2000 GMC Sonoma
    Marietta, GA
    Piston Dimensions
    The .5 and 1 mm sizes refer to oversize diameter. If your block is in good shape, you can go with standard size. If it's worn and needs to be bored, you'll have to go with matching oversize pistons and rings. A good machine shop can advise you.
    Aug 16 2016
    Navajo Nation, AZ
    Alright. Gotcha! Thxs for the info. I appreciate it. :)
