    Veteran Member Three Rings ss4's Avatar
    Jun 04 2005
    San Diego
    APB complete engine 2002 B5 S4
    Perfect running engine that just came out of my car to swap in a built motor. 105k miles on the engine. 100% stock and was running stock turbos and only a sw tune. No turbos and missing a few sensors and turbo banjo bolts for the oil lines. Has some oil leaks from the cam plugs and VC gaskets. Engine still has complete wiring harness attached, flywheel, clutch, manifolds, etc.
    $900 OBO for the whole thing.
    Brent 619-990-4093
    Senior Member Two Rings milehighkid24's Avatar
    Oct 25 2013
    Nardo Grey B8.5 S4, Casablanca White B5 S4
    Scottsdale, AZ
    I'll buy the heads from you if the price is right
    Senior Member Two Rings beomoua's Avatar
    Apr 15 2009
    Mankato, MN
    Quote Originally Posted by milehighkid24 View Post
    My guess is OP rather sell as a whole but if you're looking for 2.7 heads I have a set without cam adjusters and a set with.
    Ratified Motorsport - Mankato, MN
    Jun 04 2005
    San Diego
    I would prefer to sell the engine complete, or at least the long block all together. I could remove the harness and other accessories if needed. Right now it's basically a complete engine except turbos. Still has the starter, alternator, PS pump, throttle body, intake manifold, flywheel/clutch, etc, etc. Interested people can call/text me for additional info. Send me a PM
    Brent.
    Jun 04 2005
    San Diego
    $800 OBO
