Thanks, I thought the upper control arms get a touch during an alignment process as well, since its relatively simple to adjust the orientation of the upper control arms, which leads me to ask, how do I "properly" adjust the upper control arms before torquing and reattaching to the spindle? From the axle nut to the fender liner, is approximately 15 inches for me. Should I jack up the suspension to that distance before attaching the control arms? Also, as far installing the new controls arms go, should I just replace control arms using the same orientation as the old ones?
I'm using that VAG Factsheet / documentation as far as torque settings go, using a 16" handle torque wrench, hopefully clearance is plenty
I think I'm making progress here. Now that the strut tower is removed, I have plenty of clearance to work with clamping down the boot on the inner tie rod (driver side) using the appropriate-sized ear clamp.
This car is a daily driver, but for the last couple of weeks, the weather has been so gruesome here, it had me delaying / prolonging a successful repair and in the meantime, I've learned to improvise by utilizing public transportation and walking the very same roads I drive this car on, haha. I still have the passenger side to go through.
Thanks again.
Originally Posted by
carmudgeon
You shouldn't need to do an alignment unless you replace the tie rods. There's no camber or caster adjustment for the front.
