Results 1 to 11 of 11
    Established Member Two Rings Darkangel's Avatar
    Jan 14 2012
    2006 Audi A4 2.0T Quattro
    Keswick, Ontario
    Cost of oil consumption fix in Canada
    So... I have a 2009 Audi A4 2.0T and I'd like to know what is the Oil consumption repair cost?
    How much is the average price to fix, how long does it take?
    Stage 1 dealer fix didn't solve it, and now car is flagged TD1 so warranty repair is out of the question, so I'm wondering if anyone knows how much a shop will charge to fix the issue please
    I know the walls are good, I get the oil tested every 3rd oil change and there's no metal in it.
    Thank you.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Damn. Friend of mine has about a litre every 2000km. He spent $5600 usd at USP a week or 2 ago. But that's all parts for complete rebuild.
    What's the actual issue?? Rings?? Pcv?? If it's rings, I paid $2600 for labour getting my first engine fixed. That was replacing most of the internals of the motor though. So add price of parts on top.
    Jan 14 2012
    Keswick, Ontario
    Its just the rings, the engine works perfectly otherwise, simply literally spits oil out of the exhaust if I beat it, which since I've noticed it, been driving like a grandma keeping it under 3K rpm.
    I'm hoping that won't get to be more than $2K to just replace the piston rings.
    Veteran Member Three Rings Das Audi's Avatar
    Oct 14 2009
    Brampton
    Give Mark a call here to get his opinion or quote
    http://www.mittlermotorsports.com/contact.html
    AKA: fuzzy_onetoo
    Jan 14 2012
    Keswick, Ontario
    Quote Originally Posted by Das Audi View Post
    Will call him tomorrow.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    i got a quote of 5 - 6k for engine rebuild. which is not far off from dealer stage 2 fix of 8k. in the states they sell near mint engines for 2k
    2010 A4 quattro, Tiptronic, Ibis White
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by dracolnyte View Post
    Fully built 2.088T fsi (this calculation cud be off), oversized mahale pistons, completely built head, rods, 1.8T oil pump and housing conversion, new crankshaft, all new gaskets, Arp hardware, you name it I've got it, paid about $4500usd (plus shipping) all in. Shipped to me from Arizona. So yes your 100% correct you can get an amazing deal out of the good old US of A.
    From a USA wrecker u can likely find a low mileage for $2k ship it to cross boarder pick ups in Niagara Falls NY, if you can get seller to mark it as farm equipment you'll save a ton on duty. Pay them at there office in Mississauga and have local shop install. Done deal for much cheaper then any place in Ontario will do.
    Pfaff quoted me $3300 for labour alone. And they wudnt let me bring them parts for build. So after all was said and done I was closer to $20k for the motor I own now.
    Jan 14 2012
    Keswick, Ontario
    I need to replace my pistons on my 2009 A4 CAEB engine, I'm wondering if you could tell me if these would work with the factory rods as they're performance pistons much cheaper then stock.
    http://www.uspmotorsports.com/Audi--...5mm-9.6-1.html
    Thank you
    Feb 10 2012
    parts
    Napanee, ON
    Those look like they'll fit. Usp has awesome tech support. I'd suggest calling. And if your going in there your likely going to need to replace some bearings and seals and things like that. Lowering compression wud be good. But a 82.5mm piston should be good as its oem size. Just need to confirm wrist pin size on oem connecting rods. 21 mm sounds right. Your walls may have damage if rings have actually broken. Which could be bad news. A good clean/hone job can do wonders. If not gouged too bad
    My advice is to do it once and do it right.
    Have you by any chance removed the head and inspected yourself?? It's no 10 minute job, but you can kinda see for yourself what's going on in there. Or there's a camera scope you can use if you know someone who owns one. Take out a spark plug it all of them take a look to see which cylinder is BDC and inspect yourself. Then manually turn the motor via the crank bolt and inspect the rest. Compression test might help too. At least you'll then know where significant problem lies.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Maybe slightly off-topic, but still perhaps relevant to OP's dilemma... are there other 2.0Ts that simply bolt into the 2009-2010 A4? I.e. can one get a 2008 or 2011 2.0T engine and replace a failing 09-10 engine? Are there known 2.0TFSI engine codes without issues?
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Jan 14 2012
    Keswick, Ontario
    Quote Originally Posted by eljay View Post
    That's exactly what I'm doing.
    My buddy works at a dealership and got me a bottom end from a 2013 (post oil consumption issue) that he's getting bored 0.5 mm bigger and bolting it up to my top end.
    I'm doing all major maintenance at same time.
    All in I'll be around CDN$4500
    I'm ecstatic about it.
