Results 1 to 10 of 10
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Spare tire delete kit
    Be easy here...I threw this together with what I had laying around in about an hour. Used my home built hot wire foam cutter for the negative shapes. I think the donut and the jack/tools are an easy 45#. Kit weighs less than 5# and is built on an aluminum plate. Came out pretty good.
    Used the Slime kit plus their tire plug kit.
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Pretty good idea for raceday!
    Feb 21 2012
    Aurora, CO
    In leaving it in all the time. Donut sucks!!
    Jan 15 2013
    2013 Audi S7, 2012 Land Rover LR4 HSE
    The S7 guys will have to leave the foam piece in as it supports what looks like the valve/distribution mechanism for the air supsension. I'd also advise keeping a tire plug kit and higher output compressor in the car. Trying to fill a tire with a sub-par compressor takes forever...
    2011 Audi R8 Spyder - Ibis, 6MT, HRE P43S, white calipers, gloss black vents/trim/window frame, tints/radar/laser, UGR TT
    2013 Audi S7 - Estoril Blue, RS7 carbon diffuser, skirts, mirrors, tint/radar/laser, Eurocode sways & links, APR Stage 3 (RS7 turbo & intake, APR downpipes & AMS boost cooler), 285/35/20 on 20x10 ET25 ...GONE
    2017 Audi Q7 - Graphite Gray, BOP
    2001 Honda S2000 - Silverstone Metallic
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by achan View Post
    Tire plug kit is in there.
    Senior Member Two Rings Glacier6's Avatar
    Mar 11 2014
    Chicago
    Would the spare tire still fit with the remolding you did on the sub box?
    2019 Q8 Prestige Daytona Gray / Year 1 / Black Optic / S Line / Luxury Package / Alcantara
    2012 A7 Prestige Quartz Gray / Innovation Package / Driver Assistance Package / Sport Package / LED Headlights / B&O / 20x10 Niche M116 (Gone)
    Deactivated Four Rings
    Jun 23 2011
    Most of the new Volvo's come like this and it saves weigh. But when you cut a sidewall on a pothole you are completely stuck and only a flatbed will work. And then totally dependent on a shop that has at the least the same size tire. It happened to me in the snow in a bad area of town with 2 toddlers, not a fun way to spend a Saturday. Especially to save 40lbs on a 4000+ pound luxury car.
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by Glacier6 View Post
    Yes no problem there.. and I will say that without a doubt bass response and volume improved noticeably after removing that donut.
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by Chris@EPL View Post
    Take the good with the bad Chris. ... And watch those potholes.
    Oct 22 2014
    Atlanta, GA
    Happened to me too, tried a tire sealant which worked for maybe 20 miles and then started going flat again. Was glad at that point that i had the donut!
