Results 1 to 9 of 9
    Mar 11 2015
    Australia
    Backyard A4 B7 ENGINE SWAP 2.0T [ATTEMPT 3]
    Final attempt to save my car
    I've run out of money/parts and resources. Thought I'd give it a go here before I get it sold for scrap($80AUDyay!)
    Car - 05 A4 2.0T Quattro 145K 6spd Auto ENG CODE-BGB
    Donor Car - 05 A4 2.0T 120K CVT ENG CODE - BGB
    Is it possible to be done. I've been told it's mechanically possibly but electrically it might be a nightmare.
    Has any done a swap on something similar? how'd it go long term and short
    Any tips/info would be appreciated.
    Don't mind making a proper step by step guide and post it here if this goes anywhere
    Cheers!
    Mar 24 2013
    Oakdale, CT
    You'll need to swap the crankshaft for starters. Beyond that everything should bolt up. There should be no electrical work required for that swap.
    -Adam
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I just finished a complete 2.0 swap in a driveway. Pretty simple if you got tools. Go find a motor, in bolt your install the new. Plain and simple. I'm no pro and I'd say it's a 6/7 outta 10 for difficulty level. As stated tools are key.
    Once you've removed it install is reverse. Use caution on the electrical sensor plugs. Especially the knock sensor at the back of motor. If you cut ty raps from factory it will give you more length when u go to remove.
    Mar 11 2015
    Australia
    thank you seems a bit more promising
    Nicely done, backyard jobs are the way to go. Was yours CVT to CVT?
    So no problems between the engine being originally from a FWD CVT and being put into the QUAT. Guy from the shop I called this morning kept banging on about it being a no go.
    Don't know if it changes anything but everything forward of the engine is being swapped too
    Mar 24 2013
    Oakdale, CT
    I take that back. You should be fine w/o swapping cranks. The manual/cvt crank can be used with a tip transmission but not the other way around.
    -Adam
    Jun 17 2013
    jersey city nj
    Id thought you almost forgot....lol
    Oct 24 2015
    Perth, WA
    Im probably going to get a manual transmission at some stage. What 6sp box will work with a BGB CVT engine? Part numbers. There is a brand new 6 spd available around where I live for around 4K (dhz code). Worth it?
    My respray thread
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by Okedokey View Post
    Considering you're fwd you'd have a lot less work to do than a Quattro! Good luck with this
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Mar 01 2011
    Nanuet NY
    I swapped a CVT engine into a 6spd car. No prob. You should be able to swap a cvt engine into a auto.
    Make sure you swap all of your electrical sensors from the old engine onto the new one. Dont ask why...........................
