That is what I would suggest, but what I meant was that they can test the ALTERNATOR before you buy a new one. It can't hurt, could save you money, as it is free and can reveal if that is the actual issue. How many miles do you have? It.most likely is the alternator, but if it were the voltage regulator, you could replace that for a much lower cost.
Electrical components are finnicky. Remember that. I have a 1994 Trans Am, and she kept having issues with the engine running and then choking itself to death and shutting off while I would be driving it. Grounds were corroded, and one was loose, so I sanded the ends and tightened them up and it ran again. Eventually the optispark distributor blew up, and that's what I'm replacing now.. But back to the point haha..
I wouldn't just throw parts at your Audi. Sometimes it works, sometimes it is just unnecessary.
I also have a friend with an 01 1.8t, and when he first bought it, his battery would just "leak" its charge overnight. Swapped the alternator, nothing... turned out to be a bad battery cable.
EDIT: Do you have an illuminated battery light on the cluster while running the car?
